Old 02-12-2010, 09:55 AM   #1
BTCHN 1963
BTCHN 1963's Avatar
60-66 4x4 engine mounts
Does anyone have pictures of what the motor mounts look like on 60-66 3/4 ton 4x4, in paticular a 63. The 63 i just got has only one and it looks like a home made job. Any suggestions on replacements? I was thinking of using a cross member out of a 73-87 4x4 and modifiing it as needed.
BTCHN 1963 is offline   Reply With Quote
Old 02-12-2010, 10:36 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 60-66 4x4 engine mounts
I will try to get out and get some better pics, but I do have a 63 3/4 ton v8 4x4
Old 02-12-2010, 11:13 AM   #3
BTCHN 1963
BTCHN 1963's Avatar
Thanks i will lookforward to seeing them!
Old 02-12-2010, 11:18 AM   #4
padresag
http://www.persh.org/pickup/perches.htm
down towards the bottom of the page. the one there has the extra brkt attached for a 6 cyl
they are hard to find for a 230,250 or 283 eng as I looked for years. idid install one from a 67 which is a complete crossmember. I would advise putting that in if you are going to remove the crossmember at the bellhousing area for an a/tran
456chevy may have the stk perches for you. the ones for a 292 are different from the others
ron
padresag is offline   Reply With Quote
Old 02-12-2010, 02:05 PM   #5
cliffy
my 60 had a 283 with a horseshoe mount at the front of the block and a crossmember with left and right mounts at the transmission, but nothing at the left and right of the motor. I just swapped the drivetrain from a 80 and now have a crossmember with left and right monts at the motor and a crossmember at the transfer cas with one mount in the middle.
my o/l says the truck has a vibration at 65 mph..I said its ok, it goes away at 90.
cliffy is offline   Reply With Quote
Old 02-12-2010, 05:11 PM   #6
padresag
By rondavid, shot with E8800 at 2009-03-04
this is the 67 frt mount and crossmember installed in my 64
ron
Old 02-12-2010, 11:36 PM   #7
LILRED66
LILRED66's Avatar
Here is a pair removed, sand-blasted and powder-coated.
LILRED66 is offline   Reply With Quote
Old 02-13-2010, 12:44 AM   #8
Gus63
These are just what the ones on my 63 k10 look like. Don't know if they're the same for 3/4 tons, but mine was an original v8.
Gus63 is offline   Reply With Quote
Old 02-13-2010, 11:39 AM   #9
LILRED66
LILRED66's Avatar
They are the same for K10 & K20 trucks of the same year.
