Old 02-12-2010, 07:10 PM   #1
Number98
Prestige Worldwide
Number98's Avatar
Front end interchangeable parts Q's
Alright, so I know the following….
67 GMC hoods are the same as 67-68 Chevy hoods…
All 68-72 GMC’s fenders are the same as the 68 Chevy fenders….
So here are my questions:
Were all 67-72 GMC core supports the same? For both hoods?
Was the same hood latch used on both style hoods?
Number98 is offline   Reply With Quote
Old 02-12-2010, 09:08 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Front end interchangeable parts Q's
67/67 core supports have threaded inserts to bolt on the lower air deflector that 69/72 does not, other than that they are generally the same and will interchange... 67/68 hood latches are unique to themselves, They are taller than the 69/72's
Livrat is offline   Reply With Quote
Old 02-12-2010, 09:17 PM   #3
Number98
Prestige Worldwide
Number98's Avatar
Thanks Livrat..
I ask because I have a 70 GMC and am planning on swapping on a 67 GMC grille and hood....
Old 05-18-2010, 02:36 PM   #4
rondog4416
rondog4416's Avatar
will a hood for a 67-68 chevy truck fit a 69 gmc truck ?
rondog4416 is offline   Reply With Quote
Old 05-18-2010, 03:53 PM   #5
Number98
Prestige Worldwide
Number98's Avatar
Yes, but you will need to change out the hood latch and use a 67/68 style latch with the 67/68 hood. The core support and fenders will work with the hood.
Old 05-18-2010, 04:21 PM   #6
rondog4416
rondog4416's Avatar
thanks that helps alot.
