Old 02-18-2010, 04:17 PM   #1
iluvmy72
Poll: Is your frame too high for your rolling floor jack?
Just wondering if I am the only one with this "fun" problem.
iluvmy72 is offline   Reply With Quote
Old 02-18-2010, 07:04 PM   #2
vtblazer
vtblazer's Avatar
Re: Poll: Is your frame too high for your rolling floor jack?
lucky if I could lift the tires off the concrete when placed under the diff, let alone the frame
vtblazer is offline   Reply With Quote
Old 02-18-2010, 07:05 PM   #3
willett
Another Day, Another Dollar
willett's Avatar
yeah, whats wrong with just lifting by the axle housing?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-18-2010, 07:18 PM   #4
onlyifihadachevy
he might need to swap an axle, but even then he could jack up by the axle and then put jack stands under the frame. So back to willet's question.
And there's no poll.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 02-18-2010, 07:21 PM   #5
I lift by the axles,then place the stands under the frame when doing work that requires the axles free.I use a 4x4 or 6x6 block of wood when needed.You can lift the axles,remove tires,let down drum and rotors down onto wood,the lift the frame from a lower point thsn stock.
Old 02-19-2010, 08:59 AM   #6
ghettoluxury
ghettoluxury's Avatar
I lift by the axle and even then I can barely get the tires off of the ground and 6 ton stands fully extended barely reach the frame
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-19-2010, 10:54 AM   #7
Yukon Jack
Yukon Jack's Avatar
I generally take 6 or 8 pieces of 3/4" boards cut about 14" x 14" and stack them, then put my jack stands on them, otherwise my jack stands don't reach the frame. You can kind of see what I'm talking about in this pic
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-19-2010, 11:15 AM   #8
Burt4x4
Burt4x4's Avatar
The only time I don't need a wood block is if I'm jacking up using the bottom of the diff otherwise wood is needed.
12Ton jackstands are what I use to hold the frame/body when I drop out an axel
Otherwise like YJ w/5Ton you need to raiseum up w/wood.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-19-2010, 11:59 AM   #9
tomtuna1978
um ! ... they sell biggger floor jacks
tomtuna1978 is offline   Reply With Quote
Old 02-19-2010, 09:49 PM   #10
I never saw it as a hassle jacking any of the lifted trucks Ive had since`77.If I saw it as a hassle I know the solution...I wouldn`t lift a truck.A stock 4wd isn`t exactly much different.
Old 02-20-2010, 08:10 AM   #11
vtblazer
vtblazer's Avatar
I'm wondering if we got away from the original poster's question, iluvmy72 care to help us out and clearify the question a bit?
Old 02-20-2010, 09:08 AM   #12
Cheif Liftumup say:
"You lift`um truck,you get`um bigger jack"
"No get`um bigger jack,go get`um block of wood"
"Block of wood not biggum enough,gettum bigger wood"
"Use`um head.Jack`um up by axles.Take`um of big`um tires.Let`um back down so jack`um stand work"
What I`ve found is there`s no need to jack a truck up unless you`re removing tires(lift axles) or a rare axle removal.Then I lift,take tires off,let down lower on short stands,lift truck off axles,support with big stands,put jack under axle,lift enough to pull stands,roll axle out...not any pain at all.Pretty much how any axle swap would go.You definaitely need bigger stands than the standard car ones.I have two big and two small.I`d like to double that up to be equipped for whatever.
Old 02-22-2010, 10:51 PM   #13
Big-Blue
Big-Blue's Avatar
too tall for cheap jack stands and 7' garage doors..you would think these homebuilders, who drive trucks, would help a brother out..
Big-Blue is offline   Reply With Quote
Old 02-22-2010, 11:24 PM   #14
I`m a builder and will give any size door you want to pay for.The standard is 7' and attached garages are traditionally intended for cars.Trucks belong outside or in real garages with real doors.Most house elevations limit what height can be used.Mos don`t wan`t a large door for they detract from aesthetics.
Old 02-22-2010, 11:48 PM   #15
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
On my mudder my floor jack wont even think about the frame.
Its under the axle and two 5 ton jack stands on 2 two foot long oak 12"X12s"
powerdriver 1958 is offline   Reply With Quote
Old 02-23-2010, 12:02 AM   #16
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I have a pair of 7 ton Gray air operated end lifts, used together I can raise a truck 5 feet off the ground. Also have a Gray air lay down jack that is good for using under a differential to lift up to 3 ft. If my ceilings were high enough I would love to have a 4 post lift.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-23-2010, 12:42 PM   #17
dammitmitchell
the pollock
dammitmitchell's Avatar
i have to use pallets i made for my jackstands out of 2x4's and i have to make a ramp for m jack to be able to fully lift the front tires..
i did my axle swap with my tires maby two inches off the ground.. BUT i did it sitting straight up under the truck no problem
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-23-2010, 01:10 PM   #18
litebulblsc
litebulblsc's Avatar
Chain fall
Look closely and you can see the chain around the rear frame. Axles not mounted
http://i99.photobucket.com/albums/l2...c/IMG_1083.jpg
litebulblsc is offline   Reply With Quote
Old 02-23-2010, 02:37 PM   #19
iluvmy72
Hey....you have some nice looking equipment there. Looks also like a nice place to work on stuff....Man...if only I could have that for me!!!!!
Old 02-23-2010, 05:12 PM   #20
Burt4x4
Burt4x4's Avatar
hahaha Well, gotta give you an A for effort
Old 02-23-2010, 05:56 PM   #21
iluvmy72
no way....this is fun.....I was going to add that last week I used 2 logs from the firewood pile.
Old 02-23-2010, 06:23 PM   #22
Burt4x4
Burt4x4's Avatar
Log Splitter
Old 02-23-2010, 08:19 PM   #23
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I can even figure out how to get it under the frame
sorry guys I had too...lmao
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-23-2010, 10:30 PM   #24
Primed67
Primed67's Avatar
ha, yea same boat here. I have to get someone to lift up on the front end to get it under.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 02-24-2010, 12:33 AM   #25
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Here is my "jack stands"
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
