quick T case question
So I was looking into getting a 2 speed aux for my 2wd truck. Would it be a stupid idea to get a 4x4 transfer case and just run a driveline to the rear, and not the front? I have a muncie sm465 to use as the main trans. Thanks.
Another Day, Another Dollar
Re: quick T case question
check out my thread from yesterday on the np203.
theoretically you could put one in with a mile marker kit and then remove the actuator lever for shifting between 2 and 4wd. it would leave alot of dead weight though, and that is not a light case..... perhaps you could divorce one and machine up some kinda faceplate and yoke??
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square"
You might look at some of the companies that use the 203 Hi-lo portion for a doubler on other transfer cases. They might have a adapter that would allow it to be used like you want. It would get rid of most of the 203 weight associated with the chain drive and shaft/gears for the front drive line.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
| Bookmarks |
