leveling kit??
i have a 87 2wd, is there a kit or a way i can raise the front of my truck so it will be level w/the back??
6.0 powered square
Re: leveling kit??
yes a coil spacer
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
BAD BOW-Silverado XST
Re: leveling kit??
Check with www.jcwhitney.com. They have coil spring compressors or spacers.
Re: leveling kit??
i didnt see any, does anybody know where i can find them??
6.0 powered square
Re: leveling kit??
Re: leveling kit??
ooo ok thanks, wont these create a problem as far as alignment goes??
Re: leveling kit??
Here is another option: http://www.jcwhitney.com/COIL_SPRING...;0;2004155;0;0
I have car A.D.D.
Re: leveling kit??
I would think it would alter your suspension geometry enough to need to do an alignment.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
Re: leveling kit??
Or you could run a higher rate coil say from a 3/4-1 ton or diesel..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Re: leveling kit??
then it would ride like crap! ahhhhh!!! i wish i could just find a 2" lift spindle
Re: leveling kit??
x2...
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
haha, ford guys...
Re: leveling kit??
drop a leaf in the rear.
#13 | |
Re: leveling kit??
Your options to lift the front are few... coils, coil spacer, or spindle (old AIM spindle or covert to 88-98 lift spindle)... the first two will cause a harsher ride though it is a truck not a caddy. I never really noticed a big difference that made me think that I should take the HD coils out. Sounds like you need to drop the rear to match the front........
