brake lines with drop member
anyone have any pictures of the brake line setup they used with the drop member. i ordered one from nate this week, mine will be a little diffrent from the 3.2, but still would like to see some pics, thanks.
67cheby
![]() Join Date: Sep 2008
Re: brake lines with drop member
x2 i would like to see what you did also, i am assuming it will be all custom bent
here's mine. You will see clamps for two lines where one is empty. That will be for the air line.
The brake lines are 3/16" stainless. They are terminated to a -3AN fitting to connect a braided stainless line to the caliper. ![]() ![]() ![]() ![]() |
67cheby
man that is clean, i will be cheating off of you , thank you
nice job jlaird! Where did u get those clamps from?
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 03-05-2010 at 02:53 PM. |
![]() Join Date: Dec 2008
nate told me to use 73-80 model front lines but after seeing those, i may do that. i looks sick
here are pics with the airlines installed. They are .25" stainless.
i think i see some dust on there
The brake lines are 45 degree double flares with a manual tool. The hydraulic would be nice though! but pricey. The airlines are flareless Swagelok fittings.
![]() Join Date: Feb 2009
Nice work!
#13 |
It'd be alot cooler if you did
what exact bender and flaring too are you using? I ended up buying a very nice (and VERY $$$) 37* for my air lines but now I still have to get one to do the brake lines.
#14 |
Well the flaring tool I have I would not buy again. Its a great tool for steel, but a little wimpy when it comes to doing the stainless. It does it but you have to really show it who's boss!. Its a Snap-On/Blue Point flaring tool. If I were to buy another, I would look not further than Ridgid. I have a Ridged 37 degree flaring tool and that thing kicks 99.9% of the other brands butt. All my benders are also Ridgid. I will take picture for you guys in a second. Hold on...
#15 |
#16 |
are you supposed to double flare stainless?
#17 |
Beautiful work! I will definitely be hitting you up for a possible tech. write up on the brake line install with pics and part numbers to put on my site. Awesome!!!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#18 |
#19 |
#20 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Wow. You make it look easy!
I know for a fact it isn't. The swagelok tubing is perfect for air lines. I have some 3/8" swagelok tubing for mine,... but I think I like the looks of the 1/4" better. I guess I haven't been keeping up with your build. I'm glad to see you got a Dropmember for your truck. With the high caliber build you're doing,... your truck deserved one. Subscribing! ![]()
#21 |
keith,
I like what you did with the through frame fittings and bringing the soft line right to the frame. I wish I had thought of that! So yes, I finally bit the bullet and got the dropmember for the exact reason you stated. I will update my build thread soon...I'm waiting on a part from Nate. Last edited by jlaird; 03-06-2010 at 11:54 AM. |
#22 |
i used swagelock fittings on my dually project and could not stop them from leaking. let me tell you, you have to tighten the snot out of them. i hope you have better luck then i did. i was using 1/2 lines on my project with 200 psi pressure. maybe a smaller line and less pressure will be ok.
#23 | |
We use Swagelok fitting where I work all the time. Up to 3000psi. They work great. Usually just takes a turn and a half (8 flats on the hex nut) from finger tight, to make them leak proof.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-06-2010 at 08:20 PM. |
#24 | |
Maybe tie them to the upper a-arms like they did in the 73-87 trucks. I really like the clamps from Made4You. I ordered mine direct from Made4You,... but Summit Racing has them also.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-06-2010 at 03:56 PM. |
#25 |
jlaird,... If you ever get a chance to purchase a Swagelok brand tubing bender, buy one. There is no better bender in the industry. The even have a little tab on them that can be clamped in a vice to free up that extra hand that you need,... and don't have. Ha.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-06-2010 at 04:01 PM. |
