Finally a Bulldawg
Quicker steering ratio?
It takes a good 5-6 turns of my steering wheel to get the truck turned. I'm just wondering if there's a quicker ratio steering box that would fit and wouldn't seem like I'm turning a semi. Or would a smaller steering wheel do what I'm looking for?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh... ![]() |
December 21, 2012
I have never used their services but these guys should be able to convert your existing box to a quick ratio. quick ratio steering There may be a few others out there that can do this also.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
its all about the +6 inches
Smaller steering wheel would not chainge anything...it would still be 5-6 turns...just have to spin the wheel faster to get the reaction out of the wheels.
Recovering 67-72 Addict
![]() Join Date: Oct 2000
I suggest checking out AGR. They have several options available. I put one of their variable ratio boxes in and am very happy with it. Summit had the best prices when I was shopping.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Fabricate till you "puke"
I think a smaller wheel gives a better feel. You will still have the same amount of turns,& have to work it a little faster as Longhorn mentioned, but you arm doesnt travel as far with a smaller circle.....it just feels better to me?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
If it is a power steering box, you might try a box from the mid to late 70's. I have one from 77? and it is 3 turns. I had to change the pitman arm over to a 77 also. The hole that mounts on the shaft is bigger. Other than that it was a bolt in.
I have an 84 Burb box on the longhorn, its also 3 turns lock to lock. I had to change the hoses, pump fitting, & the pitman to bolt it on (metric box)........crazyL
