Old 03-08-2010, 10:53 PM   #1
dyno
dyno's Avatar
427 or 454: how can you spot the difference?
Hi,
I just bought a 1973 K20 4x4 flatbed with a big block. The guy says it's a 427 but not 100% sure. Could be a 454. How can you tell the difference? I can't see the block casting number. It's too close to the firewall.
Thanks,
dyno
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 03-08-2010, 11:00 PM   #2
dgodecke
dgodecke's Avatar
Re: 427 or 454: how can you spot the difference?
Originally Posted by dyno View Post
Hi,
Thanks,
dyno
Look at the boss just in front of the right head. Provided the block has never been decked and that number ground off your should see a number that starts with two letters followed by three number followed by two letters. That you can look up and it will tell you the year, size and in some cases the type of car it came out of.
Hope that helps.
07 Chev 2500HD Classic
Project Ranch Hand, Hauling A$$ since 1973
I was told this Project had a L-72 427 425HP, It did not.
It does have a 427 block and parts from various 427 motors. It will end up with a nice strong 454 in the end.
It has not been run for 20+ years
Frame up restoration started2/15/2010
dgodecke is offline   Reply With Quote
Old 03-08-2010, 11:06 PM   #3
dyno
dyno's Avatar
Hope that helps.
Is that the passenger side?
Thanks...the truck will be delivered in a couple of days so I will look at it then.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 03-08-2010, 11:22 PM   #4
f.monroe
f.monroe's Avatar
454's are externally balanced . Look at the inside of the harmonic balancer for a cast in counterweight . If it is an automatic, the flexplate will have a weight spot welded on the outer perimeter just inside the ring gear also.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 03-09-2010, 10:28 PM   #5
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Frank
Quickest and surest way if it assembled. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 03-10-2010, 10:53 AM   #6
80SPORT
80SPORT's Avatar
Often the 427 will be a medium duty high deck motor with the 4 ring pistons as these are cheap and available from buses and dump trucks...you can id these with the extra half inch of height above the water pump pads that the cylinder heads are ....also the intake manifold is wider ...
80SPORT is offline   Reply With Quote
