Old 03-18-2010, 05:28 PM   #1
project1968
project1968's Avatar
door locks????
I have a 68' C-10 that the door locks wiil not work when the doors are closed. If they are open the lock mechanism travels it full distance, but if they are closed, they wont. I put new locks in because I didnt have any keys for the old ones. Everything seems to be installed correctly. Has anyone else had these problems or does anyone have a solution.
project1968 is offline   Reply With Quote
Old 03-18-2010, 05:37 PM   #2
Sublvr72
Sublvr72's Avatar
Re: door locks????
sounds like they are not installed correctly, make sure the little fork on the inside is matched with the lock mechanism
Sublvr72 is offline   Reply With Quote
Old 03-18-2010, 06:27 PM   #3
mbgmike
Re: door locks????
Yeah door locks can be a pain. Sometimes they will lock and you can't get the key out cause they won't travel that far after they latch. You just have to keep messing with them and make sure everything is lined up.
mbgmike is offline   Reply With Quote
Old 03-18-2010, 07:09 PM   #4
project1968
Smile Re: door locks????
Well, I just got both of them to work. It actually had to do with the striker plates. They were both adjusted in just far enough that it would not allow the fork to insert itself in. After pulling each one out just enough, they both worked great...thanks for the quick replies.
Old 03-18-2010, 08:14 PM   #5
57larry
Re: door locks????
I was thinking the doors needed an adjustment
57larry is offline   Reply With Quote
