6.2 to a 6.5 swap how hard is it???
I looked at a 1984 short fleet with a 6.2 in it but its blowen up so i stoped by the motor shop to see if he had any 6.2 parts laying around and he asked me to go with him to go pick up 6 6.5s he said that i could swap blocks with no probles and said i could use what i need to get the truck up and running. He is a good friend of mine
so will a 6.5 swap with a 6.2 and is it a sign from the man up stairs to by the truck? thanks Jeff
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban
#2 | |
Conversion Truck Addicted
Re: 6.2 to a 6.5 swap how hard is it???
try this 6.2 diesel forum some great people there
http://www.dieselplace.com/forum/forumdisplay.php?f=20
Thomas Quote:
#3 | |
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Resident of Here
In 92 they introduced the 6.5. Mechanical for 1 year. In 95 it went electronic. If you get the PMD(computer) the swap is fairly easy. But if you dont then you need to get a mechanical IP(DB2). Use Google, its a great tool.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck
| Bookmarks |
