Old 04-07-2010, 12:04 AM   #1
DBear
DBear's Avatar
Sending Unit
Have any of you guys used a sending unit that is actually for a later model blazer ( like late 70's and 80's ) in your 69-72 K5?? I want to know if the sender unit's mounting head is the same diameter and will lock into a 69-72 K5 stock tank. Please help.
DBear is offline   Reply With Quote
Old 04-07-2010, 07:58 AM   #2
lks dcvn
lks dcvn's Avatar
Re: Sending Unit
Not sure about the newer sending unit, but since the 69-72 blazer tank sending units are easy to come by - why not just use the correct one?
lks dcvn is offline   Reply With Quote
Old 04-07-2010, 09:08 AM   #3
DBear
DBear's Avatar
Re: Sending Unit
that is a good point, although I am doing a 6.2L diesel swap and it requires a return fuel line and there is not one on the stock 69-72 Blazer sender units, so I am gonna run a mid 80's sender unit.....and hopefully the mounting flange is the same.
Old 04-07-2010, 09:47 AM   #4
lks dcvn
lks dcvn's Avatar
Re: Sending Unit
Makes total sense now...good luck in your search - maybe somebody else will chime in and answer your question. As long as the sending unit is a 0-90ohm unit - it should keep the gas gauge accurate as well.
