how to identify high hump vs low hump??
I was just wondering if anyone could explain to me what the difference is and how to identify them
Shake and Bake!
![]() Join Date: Feb 2010
Re: how to identify high hump vs low hump??
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
Rottenwood Garage Member
High hump is bolted in.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
High hump comes up as high as the seat bottom in front of the seat.
I think mine came factory low hump, but it has a shifter on the floor. The hump looks hastily cut. If I were to replace the entire floor (yes, it needs it) should I go with a high hump? I plan on swapping a T56 or similar into it behind a big block later on.
Only low hump floors are made.You can cut and install a high hump,though.
Two wheel drive floor pan vs four wheel drive floor pan? Are they the same?
![]() Join Date: Jan 2002
only if the 2 wheel drive had a high hump. all 4wd had high hump.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
The pans are the same and interchangeable.Only the hump itself is different.As 68350 said,all 4wds had high-hump and only big block or 4spd 2wds did.But,the impression is there for the bolting surface of the high hump.GM offered replacement cabs for a while,but only non-air low-hump.Instructions were included for adapting for both a/c and high-hump.
#10 | |
So this one is unfortunately a low-hump? And I would need a tall hump? |
Yes,you can cut the hump out,lay high hump over,drill through mounting hole locations,tack nuts underneath,and you`re done.This is what I`ll be doing on my rust free California cab for my`67 project.I`m using an M22 4spd (which works under a low hump) and I want a high hump for easier access to the shifter assembly.It`s a pain to mess with that stuff all up against the floor and over the transmission.
Alright, thanks for the info!
Chris |
