fuel cell under the bed
I finally got the fuel cell finished. What do you guys think
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Re: fuel cell under the bed
Have 10-an with an 8-return. Running a a1000 with a a1000 regulator. I need to finish up cleaning up the wiring and wash the truck. The cell looks to be leaning a little bit towards the front of the truck, but the sump is still lower than the rest of the tank. I figured if i atleast keep it full when i race, i won't have any issues..
wish i had all black fittings, but i'm going to use what i have for now. Next step is my cage, then nitrous
dazed and confused
looks good!!!
members met: redbaron69, billsbowtie,nc67 |
It looks sweet but I have heard that you don't need to mount those cells by the tabs. You might want to fab up a strap to take the weight off the tabs.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
![]() Join Date: Jul 2003
Look good, what door did you use in the bed?
thanks dj, note very well taken, didn't even think about that.
I'll find out tomorrow, i got it from a friend that did most of the installing of the tank..
Ready to go fast!!
looks good man!! time to go racin haha what kinda power does ur truck make?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
![]() Join Date: Jan 2010
looks good
meowMEOWmeowMEOW
nice, my setup is similar. That filler cover is slick too.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Apr 2005
Looks nice and should run even better,
. I'm getting ready to do that pump and regulator setup on my 68. Is there any reason why you ran the pump on the outside of the frame instead of inside? TIAR/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#13 |
I plan on moving it inside the frame rails later. I have all my battery and alternator wiring inside the frame and i need to move a few things around to get the wiring, pump, and fuel pump inside. Also, my exhaust goes up in the frame and would be to close to the fuel pump. For now, it's easy access and hidden unless you look up into the fender well...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 04-28-2010 at 09:02 PM. |
#14 |
Easy Does It
where did you get your fuel cell?
#15 |
Ready to go fast!!
how much power you got?
#16 | |
a fool with no money
I am also diggin that filler door! that square one would look soo much better than my round one...
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
#17 |
power is in the 650 range according to my dyno sheets, haven't had it to the track in a while since i don't have a cage..
#18 |
The guy that did most of the work had the cell laying around, and the filler door was on another project truck that he had. I'll give him a call to find out where he found the filler door and the tank....
#19 |
Sunburst C10!!!
awesome install
Gage 1967 C10 Shortbed Stepside |
#20 |
the filler door came from unlimited products that was made for a wood floor, but was modified to work on this metal floor. The tank, i believe is a rci 15 gal.
| Bookmarks |
