i love summertime
------>Dean23<-------
Dean
you were saying you used a newer x-member on your 68 frame right? well did you use the newer ( 73-87 ) style motor mounts or did you use 67-72 v8 motor mounts? will my 85 motor mounts and tranny xmember work on the 71 frame? thanks for the help...Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
i love summertime
ttt
i love summertime
anybody?
i love summertime
ttt
I think they would you will have to drill the holes in the frame for the 85 mounts that s about it I would use the 85 motor mounts and use the 85 front crossmember. I guess you will see when you get the frame back. Sorry about your loss.. I will be praying for you . I guess I am a step ahead of you. Do you have a welder ? I cut my frame it was pretty easy. Later Dude !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
i love summertime
dont have a welder but can weld, ill leave this to the chevy guru of my town, he has done so many of these trucks taht he can do it with his eyes closed, and a jig helps i think. ill keep ya guys posted
How Much Does he want ?
i love summertime
200 canadain, what did it cost you?
A bush cord of firewood 200 seemes worth it to me Make sure he does a dimond plate over the lap joint. Good Luck Mario
i love summertime
lap joint? wouldnt he butt the frame up and then weld, if you do a lap i cant see it coming out straight like it was before...it would be offset the thickenss of the frame??? im new to this, so please tell me whats up
Did you see pic on my other post ?
I couldn't get the later style mounts to work out right without spacing them off the top of the frame with washers. I ended up using the original style v8 mounts.
69 SWB LT1/4L60E www.classicplace.com |
