How to I reduce slack in steering?
My steering wheel has about 3 inches of side to side play before any actual steering happens. What is the solution to take out slack? My truck is 1970 C10 with original manual steering.
thanks Mark |
Re: How to I reduce slack in steering?
Hi there, I'm sure that you will receive a lot of good technical advice that is better than mine but I have learned one thing from past vehicles and that is that replacing the Idler arm can take out a ton of play and doing so gives a lot of bang for the buck. Of course there are other steering/front end components one can go through as well but simply doing this one thing has turned cars from undriveable to drivable for me.
Six in a row makes it go...
![]() Join Date: Mar 2009
If the idler arm is good and it's the box that is sloppy, there are instructions in the service or overhaul manual on how to adjust the worm rack (slotted screw with jam nut). My experience has been that you only get so much out of this - it won't perform a miracle.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
tyrod ends idler arm pitman arm and ball joints all may have wear after 40years
that steering box adjustment is a very stopgap method at best// it can cause alot of pressure on the worn box and lead to a steering box failure at the worst possible time
First try adjusting the steering box. On the top of the box is a threaded stud with a slot cut accross the end facing up. This stud is kept from turning by a lock nut at its base. This stud takes the slop out of your box. Jack the truck up so both wheels are off the ground. Make sure nothing has been placed in the way of any parts that will move when you turn the steering wheel lock to lock. Now loosen the lock nut and while holding the lock nut with a wrench use a big flat blade screwdriver inserted into the slot of the stud and turn the stud in (clockwise). Try 1/2 turn and see if the steering has gotten any better. Keep going in 1/2 turn increments until you have gotten most of the slack out. If the screw gets tight (meaning you have meshed the gears completely tight) stop and back off 1/2 turn. You only want to turn the stud in until you have taken the slop out. Once done tighten the lock nut down and turn the steering wheel slowly from lock to lock feeling for any tight or binding spots. If there are any loosen up the lock nut and turn stud out another 1/2 turn. Any tight or binding areas could cause the steering wheel not to center properly while driving or completely lock up on a turn. While the truck is jacked up check all steering components also. The idler arm is a good place to start as stated in a thread earlier.
The Older Generation
If you tighten it up too much, when you turn a corner you won't be able to straighten it up and you will drive through a fence and almost hit a tree... Ask me how I know... ![]() If it is the steering box that's bad go to your friendly auto parts store and buy a replacement. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-26-2010 at 05:28 PM. |
First jack it up & get under it. Start pulling & pushing all the joints & kingpins. Anything with play or looseness needs to be replaced. With that much play I'm sure it or most of it is in the steering gear. If it was a small amount you can adjust it but with a lot of play it needs to be rebuilt. They are not that hard to rebuild & when the front end on these trucks are right they are a pleasure to drive.
Re: How do I reduce slack in steering?
Thanks to everyone who replied. Where does one go to get a replacement new or rebuilt steering box?
sharp as a marble
![]() Join Date: Jan 2007
all of the above.
If you have a jack and two jack stands ( to be safe) Jack one side of the truck at a time: get the jack as close to the lower ball joint as you can. Once the wheel is off the ground, take a long pry bar, and raise and lower the tire at the 6 oclock position. Have someone looking for loose play in the upper and lower ball joints. Then take your hands and grab the tire at the 3 and 9 o clock position and have someone look for loose play in the steering linkage. if something is loose, then fix it. IF the steering box is worn out, you should be able to turn the steering wheel, and see the steering shaft move all the way to the top of the steering box. Then you will see no movement at the bottom of the steering box. Adding power steering to our truck is pretty simple. go to the local parts store and buy a reman power steering box $200-$250. then it gets a bit hard. you will need a P/S pump,pulleys,hoses, and some fluid. I will tell you that you will be glad you did this !! Last edited by cparman; 04-26-2010 at 09:09 PM. |
autoparts store
#11 | |
Hellasick
![]() Join Date: Jul 2006
![]() Or wait and tell it around the campfire.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
What?
hmm 3" isn't too bad, and I'd think you wouldn't want to have a completely snug steering with a manual box. Since if you hit a curb, or rock it could jolt your steering wheel abruptly enough to hurt your hand.
<I'm no expert, so I may be TOMA> So... As far as getting a new rebuilt steering gear, just about every one of the resto parts vendors carry those. So pick yer poison.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#13 | |
![]() LockDoc
#14 |
#15 |
72 GMC
#16 |
I've seen listings for "quick ratio" boxes in some of the catalogs catering to our trucks ... the claim is about 1 turn less, lock-to-lock. Any experience?
Barry
Barry L. Van Hook '69 Chevy Frankentruck Last edited by barryvanhook; 04-27-2010 at 02:52 PM. |
