Old 01-31-2001, 12:32 AM   #1
Rayzor
Post S10 tranny
Does anyone know what tranny was used in the 88 s10? Its automatic 4 speed. A 2.8 liter was in front of it. Also will it bolt to a 307?
Rayzor is offline   Reply With Quote
Old 01-31-2001, 10:47 AM   #2
BCSchutt
Post
I have a 91 S10 and so does my friend, we bolted on a 350 with very small adjustments (motor mounts)as for a tranny if your wanting to replace it with the engine i wouldn't use an original tranny we replaced ours with a TH400 and customized a driveline.
Currently rebuilding 1980 Chev c10 lowrider
1970 Chevelle Dragster built 396 lots of power and rebuilding a 1972 chevelle 250 straight 6 and 3 on the tree
BCSchutt is offline   Reply With Quote
Old 01-31-2001, 11:45 AM   #3
JJR
JJR's Avatar
Post
From what I have heard, no. The 2.5 and 2.8 liter S-10 used the same 700R4 transmission but the 4.3 liter used a different one. The trans off a 4.3 liter would work on a small block but not from a 2.8 liter. The bellhousing bolt pattern will be different.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 01-31-2001, 12:36 PM   #4
ImpalaSS
Post
we blew a trans in a 80s s10 once..... i was looking at the old one and the bolt pattern was WAY diffrent
btw it didnt have the 4.3
www.xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside
64ImpalaSS 327 700R4
67 1 ton dually 157" wheelbase 327 SM420
ImpalaSS is offline   Reply With Quote
Old 02-21-2001, 02:14 AM   #5
hugger orange
Post
The tranny would be a 700R-4. No it will not fit. The 2.8 was a 60 degree block. The 4.3 and V8's are 90 degree block, different bolt patterns.
'72 C20 Camper Special, rebuilt 402BB, TH400, Dana 60, 3.54.
http://bernie.4t.com
hugger orange is offline   Reply With Quote
Old 02-27-2001, 03:37 AM   #6
herauf
herauf's Avatar
Post
what about a 96 s10? it has the 4.3 in it... how much modification would be required?
1987 k5 4x4...FOR SALE!!! (email for details)
will eventually be replaced by a 70-72 4x4 k5
herauf is offline   Reply With Quote
Old 02-28-2001, 11:39 AM   #7
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Post
Some of the 2.8L's Had TH200s (3spd) and 200R4s (4spd overdrive)
Toms River NJ
71 custom 20 - 307 3onthetree (bone stock & 4 sale or trade)
56 working Street rod (under construction)
92 Olds 98 land yhat..(wifes)
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 03-02-2001, 12:01 AM   #8
fast_dev
fast_dev's Avatar
Post
will not work from a 2.8, only from a 4.3 as someone said before. 2.8 is 60 degree block and 4.3 is 90 degree.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
