406 Powered
Gauge problem? Bad oil pump? ???????
Got the 406 in my truck and it will scream, but oil pressure gauge registers around 5-10 pounds of pressure at idle. I used all good parts but am wondering if it could be the gauge. Got a white face sunpro gauge. When your cruising the pressure is up around 40-50. No engine noise but is it possible the new oil puimp could be bad? Or cheap oil pressure gauge?
70 GMC 68 c10 2002 silverado 72 4x4 |
Re: Gauge problem? Bad oil pump? ???????
electric or mechanical?? if electric it could be bad battery,charging system or wire connections
406 Powered
Mechanical......
Shake and Bake!
![]() Join Date: Feb 2010
What is your idle set at? My 350 will push about 22-28 psi at idle, 50 psi at cruise and 60 at wot. If your idle is set really low it could be giving you your low numbers.
I have my idle set at about 850 rpm's in park and that puts me at about 650 rpm's in gear. Unless you have a leak in your gauge line, these mechanical gauges are pretty close to right. Also, I have never been one of those guys that has been a big believer in synthetic oils except in my diesel trucks. But odd as it is I gained about 5-8 psi at idle when I switched to a good syn...who knows?
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
#5 | |
406 Powered
![]() Join Date: Aug 2001
A GOOD RULE OF THUMB IS 10 LBS OF OIL PRESSURE FOR EVERY 1000 RPMS.(BIG DIFFERENCE BETWEEN 5 & 10 lbs AT 1000 RPMS) I'VE HAD THAT SAME PROBLEM A TIME OR TWO. AFTER YOU RULE OUT THE GAUGE & PULL THE OIL PAN TO CHECK THE OIL PUMP,(A REAL PAIN.. BUT POSSIBLE) PULL A COUPLE OF MAIN CAPS & LOOK AT YOUR BEARINGS. IF THERES ANY COPPER SHOWING OR YOUR CRANK JOURNALS ARE GROOVED OR THE FINISH DOESN'T LOOK POLISHED, PULL IT IMMEDIATLY & FIX IT. IF YOU DO.. DON'T FORGET TO SWAB OUT & CLEAN THE OIL GALLYS OR YOU WILL BE DOING IT AGAIN IN ANOTHER 2000 MILES. DON'T ASK HOW I KNOW.
![]() GOOD LUCK WITH IT. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 05-02-2010 at 03:36 PM. |
406 Powered
Thanks. I hope its just a bad gauge because everything is brand new. Anyone ever had a bad gauge even though it was new?
dazed and confused
yep. mine came from advance. sunpro i think. it was swapped for another set
members met: redbaron69, billsbowtie,nc67 |
i never have.. But i always check it first, & look for a kink in the line... But i've never been that lucky. (it only takes about 5 min.) i have a 454 crankshaft that i welded to a 8"rally & the other end to a 6" vice. It serves as a daily reminder not to trust anybodys word on motor work. High dollar vice stand that i've had for over 20 years. As you probably know.. The price of admission is very expensive to this hot rod hobby. Good luck bud. Hope its something small & cheap. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Cruzin
My 383 in my nova has always run oil pressure about the same numbers as you are running since it was built (me and dad built it) dad said that a sbc motor does fine at 5lb pressure idle and 30lb pressure going down the road thats fine (he was a mechanic for 30+ years and dirt track raced for years) so i trust his judgement, not saying your 406 is the same but just saying so maybe to sure your mind alittle
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
406 Powered
Was it the oil gauge? What did it do?
406 Powered
copper line...no kinks...
#13 |
![]() Join Date: Sep 2000
what oil filter do you have
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
#14 |
Big Red - Now its a SWB!
What weight oil are you running? If you are running light oil the pressure will be lower. You lose a little power (less than 1%, so not much) running heavier but you will have more pressure. Of course this doesn't mean that you want to run the heaviest oil you can get, but I'd ask an engine builder that you trust what they recommend for your build. My engine builder recommended that I run 20-50 because of the summer heat we get (110+).
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#15 |
dazed and confused
nothing. hooked up and nothing. i dont what was wrong with but the next was fine.
#16 |
406 Powered
Thought of that. running wix oil filter. Engine builder recommended 15/40 rotella. My brother runs 15/40 in a 700 h.p. dragcar with no problems. Might change the oil filter even though its new.
#17 |
![]() Join Date: Sep 2005
wix is a good filter dont think your problem is there your pressures sound normal to me 10 psui at idle and it should increase about 10 psi for every 1000 rpms
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#18 |
Sounds Ok for me too, I have run motors with that oil pressure for a long time. AS long as the pressure goes up when you hit the throttle you should be fine. If the top end of your motor is not getting enough oil it will let you know when the rockers start to make noise.
