Old 02-11-2003, 12:41 AM   #1
GreenMystChevy
lost my keys..what to do...fast
Ok, my dad lost the keys to my ignition for my truck and I don't have a spare. What would be the best method of getting this thing back on the road? It is about 30 minutes away from home and I have to take care of it first thing in the morning.
Do I call a locksmith? Go buy another ignition assembly with key first thing in the morning? What is easiest and cheapest? Can I change out the ignition thingy easily and not at home because I don't know how to do this. Help me out quick guys.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 02-11-2003, 12:44 AM   #2
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
Since the steering wheel dosent lock. Just run a temporary hot to the ignition and jump the starter and drive it home and replace the ignition later.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 02-11-2003, 12:57 AM   #3
spinning wheels
spinning wheels's Avatar
Do you have AAA or some kind of tow service? Removing the starter ignition without the key, is not all that easy. Remember, you need the key to turn it to acces. position first. Good luck
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 02-11-2003, 01:05 AM   #4
Piston
Piston's Avatar
buy an ignition switch, unplug your wiring connector and plug the new switch in, use a pair of needle nose pliers to turn/start the truck and drive it home. From there you can take your old lock out and have a locksmith cut a new key for it. Or better yet just replace the lock cylinder along with the new ignition switch. I'd bet you would have a total of 30 bucks with both items.
Piston is offline   Reply With Quote
Old 02-11-2003, 01:11 AM   #5
68 Suburban
68 Suburban's Avatar
Call the locksmith and let your dad pay the bill. After all he lost the keys.
68 Suburban is offline   Reply With Quote
Old 02-11-2003, 01:12 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
But then his door keys wouldn't match his ign key.
If you have the $$, call a lock smith. That'll be the easiest and the quickest way to get it done and home.
Then you need to get a copy made. (not that I have room to talk about gettin copies made)
Old 02-11-2003, 01:29 AM   #7
swede413
swede413's Avatar
pull the plug off the ignition now stick a 3" wire in the the spot that the red wire is running to stick the other end in any of the other holes if the starter turns rember where that hole was and keep trying tell your heater runs leave that wire in the hole that makes your heater run then take one more wire red to the hole that made your starter turn and leave that one in just long enough for youe truck to start, now drive home
70 blazer 350 3on tree
98 GMC 3/4 ton 4x4 5 speed manual
swede413 is offline   Reply With Quote
Old 02-11-2003, 10:15 AM   #8
Blue Beard
Blue Beard's Avatar
You don't need to buy a new ignition switch......
Just buy the cylinder.....or buy the door and ignition cyl set.....
That way you'll have locks that match when done.
The little hole in the ignition (assuming this is a 67-72 truck) is the removal tool. Simply use a paper clip in the little hole.......a no good key in the cylinder and while pushing in with the paper clip pull out on the lock with the key.
The key being the wrong one will pull on the tumblers inside and help with the removal.
Now with that out you could use a screwdriver to slip in the slot and start the vehicle.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-11-2003, 01:49 PM   #9
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Ignition and door keys the same? Not on mine. ITs a 67, did that come that way in 67?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 02-11-2003, 01:55 PM   #10
JHickson6
I Love This Stuff!
JHickson6's Avatar
i'm with 70shortnphat, jump it!!! Practice is always good!!!
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 02-11-2003, 01:58 PM   #11
Blue Beard
Blue Beard's Avatar
stelth2002
I have a parts book that shows 67-72 door and ignition locks (replacement) with the same key....
Should have clarified that not all units were made with matching keys originally.
I know of one shop that sells the complete set with a glove box that also is keyed to the same.....
Sorry about not clarifing that, but glad you inquired......
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 02-11-2003, 02:01 PM   #12
Project1970
14.1 @ 96MPH
Project1970's Avatar
I don't know about factory, but it's no problem to get a matched set these days. I did it because mine were unmatched (they were matched originally but the ignition switch and cylinder got so worn it'd switch to off in a turn!) and because the door keys were so thin it wasn't even funny.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 02-11-2003, 02:08 PM   #13
Low68
Low68's Avatar
If I were you, I would replace them for safety issues. Someone somewhere has keys to your truck, and if you replace the ignition lock cylinder, they will no longer have keys to your truck. But also keep in mind that it will be a real pain to get that lock cylinder out of the ignition switch with out a key. Just some thoughts. Good luck
Low68
Build Thread
Low68 is offline   Reply With Quote
