Old 05-16-2010, 03:13 PM   #1
Hair
best procedure for door install
I'm fixin to put my doors back on. Never done it before.
My plan:
Bolt hinges to door, setting them at the middle of the slots.
Set door in cab (put a paint paddle under the bottom to hold it up off the rocker?)
Hold it and get the gaps looking like I like, and then tighten the hinges up on the cab.
I can see a million things going wrong with this process
I don't know... what's the best procedure for putting a door on and getting it aligned?
Hair is offline   Reply With Quote
Old 05-16-2010, 04:15 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: best procedure for door install
My experience on doing this is limited but the few times I've done it I shimmed like you're planning on doing and the rest was strictly trial and error. Mostly move top or bottom one at a time until you get it the way you want it.
Might help if you can get a buddy to help you.
68gmsee is offline   Reply With Quote
Old 05-16-2010, 04:34 PM   #3
El Jay
Gone to greener pastures
Take the striker off the door jamb before you start so you don't accidentally get the door jammed tight & unable to open.
Replace the striker after you get the door adjusted to where you want it.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-16-2010, 04:50 PM   #4
cdowns
cdowns's Avatar
i use engine hoist to hold door while i boltup hinges
Old 05-16-2010, 08:56 PM   #5
Fastfun
Fastfun's Avatar
Thats a good idea I will have to remember that when I install my doors
Fastfun is offline   Reply With Quote
Old 05-17-2010, 09:41 AM   #6
custom70
custom70's Avatar
If they are painted, make sure you tape up the edges to help avoid dinging them up!
custom70 is offline   Reply With Quote
Old 05-17-2010, 05:45 PM   #7
Sammy
I used a 14" 4 X 4 on a floor jack balanced it the best I could started those bolts in the door. These are doors are heavy even with a helper. Pay attn. to the fine threaded bolts in the hinges..They are easy to cross thread.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-17-2010, 09:41 PM   #8
turp mcspray
turp mcspray's Avatar
I bolt the hinges to the post, then set the door on my knee and bolt it to the hinge. When empty, these doors are light as far as doors go. These trucks are about the easiest thing there is to hang a door onto. Don't make it harder than it needs to be. Make sure you clean the threads with a tap and die first. This alone will make things much easier.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 05-17-2010, 10:20 PM   #9
gkesseru
gkesseru's Avatar
1. Get it hung and to the point where it swings without binding.
2. Adjust up/down so the body crease lines matches in the up/down direction by adjusting the bolts on the body pillar. Also adjust for front/back clearance at this time.
3. Put the latch plate back in and adjust latch plate bolts so the the door is level to the body right at the latch plate. You may have to add/delete latch plate spacers. Use a straightedge to check for alignment. If don't have weatherstrip, pull out on the door when you measure.
4. You can then move the top and bottom hinges in and out until the door is parallel to the body. You do this by adjusting the bolts on the door. Also check alignment at the front roof pillar where it meets the door body at this time.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
