Old 05-18-2010, 05:50 PM   #1
deadzero72
Restoration questions
Alright i will start out with saying this is my first restoration and I'm 19. I have a 1972 chevy k20 350. i just want to see if anyone else has tackled these projects. i want to switch my th 350 over to the 700 r4, so can i reuse the stock crossmember or do i need to buy a certain one? also does anyone know where to find a column shifter that would have PRND321? or should i just go without first gear selection? thanks for any input.
deadzero72 is offline   Reply With Quote
Old 05-18-2010, 06:00 PM   #2
coop34
Re: Restoration questions
You can use the same crossmember. You'll just have to move it back a bit and drill some holes in the frame to bolt it up. I just did this on my truck last night.
coop34 is offline   Reply With Quote
Old 05-18-2010, 06:04 PM   #3
Southcity
Southcity's Avatar
I've seen the shift indicators you are looking for (PRND321) at Jegs, check the below link.
http://www.jegs.com/p/Ididit/Ididit-...55116/10002/-1
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 05-18-2010, 06:10 PM   #4
deadzero72
ok thank you also how did the transmission fit after you switched over? is the any extra modification i will need to do? i heard you need to change the shifter linkage to make it work. is this hard to do?
Old 05-18-2010, 06:31 PM   #5
coop34
Haven't gotten to the shifter linkage yet, but you will probably also have to shorten the drive shaft. I did anyway.
Old 05-18-2010, 06:40 PM   #6
deadzero72
i figured i would have to do the driveshaft so im saving for that. but thanks you guys for the input
Old 05-18-2010, 09:24 PM   #7
gkesseru
gkesseru's Avatar
If you switch to a 2004R instead, you won't need to change driveshafts. The stock crossmember will need to be slid back a couple of inches.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 05-18-2010, 09:36 PM   #8
Hubscrub
Cruzin
Hubscrub's Avatar
lmc has one i got it for my truck i says "with tilt" but haven't installed it yet on my non tilt column
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-19-2010, 02:03 PM   #9
deadzero72
ok that works out i have one of those magazines.
Old 06-12-2010, 01:33 AM   #10
deadzero72
trying to revive this thread again ha ha. but has anyone finished this restoration part yet. i have the 700 r4 ready to install and just wondering how hard it is to mess with the linkage to make it shift?
Old 06-12-2010, 01:42 AM   #11
blazin
i did that swap in my 72 blazer.. tanny is 2 1/2 inches longer i believe and i ended up going with a b&m shifter. i just took the shifter off the column. but a year later and im putting in a flaming river tilt floor shift column.. well its ordered.. another week and it should be here.
blazin is offline   Reply With Quote
Old 06-12-2010, 01:45 AM   #12
Dads69C10
Dads69C10's Avatar
Does a 700R4 require a trans cooler?
1969 C10 stepside
1973 Cheyenne Blazer
Dads69C10 is offline   Reply With Quote
Old 06-12-2010, 02:50 AM   #13
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Yes, All automatics do.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
