Old 05-26-2010, 04:13 AM   #1
frisco kid
frisco kid's Avatar
any one lay frame and still have ac
Hey guys , im about to get the porterbuilt bolt on rear bagg set up so i can lay frame. afterwards im going to take on the front, im getting the porterbuilt dropmember and bag set up. i have 16 in torque trusters with 235- 60-r16 tires not very tall. and i have the vintage air complete replacement ac for a 71 fleetside and if you have layed frame and have a set close to this or can just give me a hand or let me see your build pics get at me thanks
frisco kid is offline   Reply With Quote
Old 05-26-2010, 06:43 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: any one lay frame and still have ac
I think an aftermarket A/C unit is necessary to use the Dropmember.
You have to eliminate the big bulky A/C underhood box that came on these trucks.
Sorry I haven't done this,... but maybe someone else will chime in with info or pics.
Keith
Convert to disc brakes.
Old 05-26-2010, 12:30 PM   #3
GVizzle
GVizzle's Avatar
My build is incorporating a vintage air system an will lay frame with a 29" tire
do a search for "old aux" Nate documents the entire build on the thread, might help you out or give you some insight. good luck.
GVizzle is offline   Reply With Quote
Old 05-26-2010, 01:00 PM   #4
frisco kid
frisco kid's Avatar
Thanks man i will check out old aux nathan doc. and for the guy who said i need an after market ac i do have the vintage air complete replacement for a 71 fleetside with a big block so i dont have the old ac in at all thanks guys.
Old 05-26-2010, 01:15 PM   #5
frisco kid
frisco kid's Avatar
could someone send me a link to a thread couldnt find old aox
Old 05-26-2010, 01:38 PM   #6
lolife99
lolife99's Avatar
OLD AUX thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=358687
Keith
Old 05-26-2010, 11:47 PM   #7
5windowpickup
5windowpickup's Avatar
I have the stock ac box and I am laying out on a 28" tall tire with a dropmember and a stock spindle. My upper control arm is hammered into the box when its layed out. Check out my build thread for some pics.
Josh Hart
High Octane Hotrods
71 C10 Bagged work in progress driver
Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912
5windowpickup is offline   Reply With Quote
Old 05-27-2010, 12:11 AM   #8
frisco kid
frisco kid's Avatar
Hey thank you man nathan told me to get ahold you. i wonder if i could make mine fit with my 16 in rims, you got yours to lay frame with the stock ac thats crazy! anyway thanks ill put up pics when i start cutn on it. good looking truck by the way.
Old 05-27-2010, 10:59 AM   #9
67cheby
67cheby
67cheby's Avatar
Heres a pic of one laid out with factory ac/ not mine, this is 5window, i didnt see his post before i posted this pic
67cheby is offline   Reply With Quote
Old 05-27-2010, 05:39 PM   #10
csa daddy
csa daddy's Avatar
looks like it has a drop member in it but i would like some more info on that paticular truck
csa daddy is offline   Reply With Quote
Old 05-27-2010, 06:00 PM   #11
67cheby
67cheby
67cheby's Avatar
scroll up 3 posts and click on his build thread,
Old 05-27-2010, 06:01 PM   #12
67cheby
67cheby
67cheby's Avatar
click on this build thread 71c10
Old 05-27-2010, 11:49 PM   #13
5windowpickup
Thanks! I still need to hook it all back up but you can get the idea. You should be able to lay out, your tires are only around 27" tall so you shouldn't have any problems. It's all about the overall diameter of the wheel and tire. I will be switching to a 20" wheel and as long as I stay around the 28" overall I will still be able to lay frame. Keep us posted with updates and if you have anymore questions just ask!
Josh Hart
High Octane Hotrods
Old 05-28-2010, 11:24 AM   #14
osaltyone
osaltyone's Avatar
Here is an example of what I was going to do with my blower box, but this is for 73+. I took the pic from another site.
osaltyone is offline   Reply With Quote
Old 05-28-2010, 02:47 PM   #15
csa daddy
csa daddy's Avatar
you remember wat web site it was
ac lay frame vintage air
