Old 05-26-2010, 10:19 PM   #1
Dapper Dan
Dapper Dan's Avatar
Do I need drop shocks?
It's an '87 front is 3" spindles and 2" springs, rear is a flip kit with shock extenders. Can I use stock shocks, or is there benefits with drop shocks? Also if I do need drop shocks on the front do I need 2" or 5"?
Thanks Dan
Dapper Dan is offline   Reply With Quote
Old 05-26-2010, 11:16 PM   #2
SCOTI
SCOTI's Avatar
Re: Do I need drop shocks?
I always measure the shock mount dimensions @ ride height & compare them to the shocks dimensions (extended/collapsed). If you opt to get shocks w/o investigating, you'd only need ~2" drop since the spindles don't alter the shock travel.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
