Old 05-28-2010, 11:52 AM   #1
minime's 68'
35's with a 4" lift
I have a 68' and I'm going to swap axles with a 70' 4x4 and was wondering if anyone knows if I can fit 35's with a 4" lift without moding the fenders. Any help will be appreciated thanks!!
minime's 68' is offline   Reply With Quote
Old 05-28-2010, 05:26 PM   #2
88K2500
88K2500's Avatar
Re: 35's with a 4" lift
I can't answer your question but I can tell you that the offset of your rims plays a big part in weather or not your tires will rub on the inner fenders or not. What rims are you running?
88' k2500 LB P/U,4x4, 5.7L, 2.5" Lift, 33"BFGs, 10K Warn
86' K2500 Suburban,4x4, 3/4 ton, 5.7L, 4" Lift, 33" BFGs
88K2500 is offline   Reply With Quote
Old 05-28-2010, 05:54 PM   #3
minime's 68'
16.5
Old 05-28-2010, 07:14 PM   #4
mstrav1973
mstrav1973's Avatar
mine dont rub
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 05-28-2010, 08:29 PM   #5
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
You might have a problem finding a 4" lift for a 68'. I think 67-68's are the years that take a special lift kit compared to 69-72'. There is something different about the frame or leaf spring mounts. I have the same lift kit has mstrav has on his truck, 4" Rancho and it clears 35" BFG mud terrains without any rubbing at all on 8" wide rims. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-28-2010, 08:38 PM   #6
mstrav1973
mstrav1973's Avatar
Is it the leaf springs for 67-68 that are shorter and would be the issue? If he's just swapping in axles from the 70 that shouldnt matter should it?
Matt
Old 05-28-2010, 08:52 PM   #7
71blksuper4x4
SWB 4x4 Collector
The swapping of axles wouldn't really affect the lift kit. There is something special about 67-68 frames that I know 69-72 lift kits won't work with. Something was brought up awhile back about the issue, but I don't remember what is is. I have never owned a 67-68 to know. Trevor
TREVOR
Old 05-28-2010, 09:27 PM   #8
72freak
Rottenwood Garage Member
72freak's Avatar
I dont recomend runnung 36's like I have on mine unless you are NOT going to be off roading. As a matter of fact....be carefull with 35's also. This is 4" lift. Oh yea....."For Sale"
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 05-28-2010, 10:54 PM   #9
minime's 68'
Thanks for all the input. I'll start measuring as much as I can!
Old 05-29-2010, 06:45 PM   #10
Travis K
Travis K's Avatar
I am installing a 4" Rough Country lift on my 68 frame. I am having a few issues with fitting it. I couldn't find a lift for a 68, so I purchased a lift for a 69-72 with 56" springs. The first issue I ran into is that the spring eyes on the leaves are quite a bit narrower than the shackles. That is not too difficult of a problem to fix. The main issue I am having is that the 56" springs are still too short. On the rear end, the shackles contact the bracket before it is even off of the ground. When it is set back down, the shackles sit at about a 45* angle pointing towards the front of the truck. I do not have any reference photos, but I would think that the shackles should be near vertical when they are at rest? I would get some photos of the issues I have had, but I am currently deployed. If anyone has any ideas on how to fix this, let me know. I was thinking of relocating the rear shackle hanger forward a couple inches. Does anyone see any issues with doing this as long as the centerline of the axle stays the same?
Travis K is offline   Reply With Quote
Old 05-29-2010, 07:17 PM   #11
minime's 68'
Travis K Thanks for the heads up.
Old 05-29-2010, 07:37 PM   #12
minime's 68'
I found a lift kit for a 67-68 Suburban. Is there a difference between the truck leaf springs and one's from a suburban? Does any one know?
Old 05-30-2010, 07:07 PM   #13
Chevymaniac
My understanding is that the springs on 67&68 are 3" wide where as 69-72 the springs are 2.5" wide. The 56" long leafs are found on 1 tons and 52" long leafs are found on 1/2 and 3/4 tons. Hope this helps clear things up for you.
Chevymaniac is offline   Reply With Quote
