![]() Join Date: Oct 2007
What Goes In This Hole ?
I am talking about the hole in the firewall right above the wire that is comming out for the heater fan . It is about a 2 inch diameter hole .
I have looked up "Search" and none of the firewall pictures have a hole in this area exposed and labeled,, gp ![]() A closer up LOOK ![]() Last edited by GOPAPA; 06-03-2010 at 12:55 AM. |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Re: What Goes In This Hole ?
Pretty sure that somebody added that after it left the factory.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
![]() Join Date: Jan 2007
agree with above
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
69 Fleetside
![]() Join Date: Mar 2009
Somebody got busy with the hole saw - mine doesn't have that...
1969 Chevy C10 Custom Camper - "Frame On" Restoration Blueprint 383 w/ 405hp@5200rpm & 441ft-lbs@4200rpm / Jegs TH350 w/2300 Stall / Drivelines NW 2-Piece Shaft / stock 3.08's / CPP 4" Drop Rear, 3.5" Modular Drop Front |
good luck finding a plug for that. mine doesnt have that either and I have never seen one there.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
Mines got 2 holes there. Someone had put in an aftermarket A/C unit and that's where they routed the lines to the evaporator. I have aluminum tape covering the holes till I can get in there and weld a patch panel in...
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
Try the home store hardware section with the drawers of strange stuff. I don't know if any are big enough, but there are round pop in sheet metal plugs that I've used to make some holes less obvious...
If you want a quick fix, get a household door handle blank-off plate. Similarly, there is a round plastic plate available to protect your wall where door handles hit.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
No hole there from factory.The auto paint supply shops around here have racks with misc trim parts on them with an assortment of plugs & such.An old style NAPA might be able to help,if you can find someone who can use a parts book.........................Bob
1967 C20 Custom - 396/TH400 1968 GMC short step-350/M21 |
An electrical supply house will have what is called an "oil tight hole seal" http://www1.mscdirect.com/CGI/NNSRIT...59556&PMT4NO=0
looks like: ![]() ![]() made from steel and can be painted to match.
#11 | |
Exactly what I am going to do ..I remembered from my construction days seeing these in electrical panels . You beat me to it as I was going to go today and try and get one of these Fleet72 and show all what I came up with..thanks for the pictures . Rather than burn up my new paint with a patch and weld this works just fine with me . I will do my Vinegar trick to galv. on the engine side of the cover and then under coat it and paint it the truck color .. It will be my conversational cover up story about my truck..LOL thanks again all of you for the replies..gp |
#12 | |
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper Last edited by FLEET72; 06-03-2010 at 11:00 AM. |
#13 | |
