Old 06-06-2010, 09:17 PM   #1
873+3/90zuk
torque converter???
just lost the th400 in my 87 crew 4x4 6.2l. ive got another in my shop but i need to change out the torque converter to a diesel one. i found one at summit for $100 but the lowest stall they have is 1700. is that low enough? were else can i get one that wont break the bank? i read that the stock stall is around 1300 is that true?
thanks
873+3/90zuk is offline   Reply With Quote
Old 06-06-2010, 10:07 PM   #2
clinebarger
Re: torque converter???
thanks
A higher stall is not a good idea with a diesel. Diesel transmissions have different valve body calibrations & governors than gas engines. Is the replacment from a diesel pick-up?
clinebarger is offline   Reply With Quote
Old 06-06-2010, 10:54 PM   #3
873+3/90zuk
no the replacement is from a gas rig. i was under the imression that all i needed to do is change the torque converter/vac modulator and gov over to the diesel stuff and she would be good to go behind my 6.2. im looking for a stock diesel torque converter stall so i can source one online.
Old 06-06-2010, 11:08 PM   #4
BB4ME
you can use it I just did the same thing to my 83 6.2 get a converter from dacco for 64 bucks installed no problems pushed snow all winter with it.if you need more info hit me up.
BB4ME is offline   Reply With Quote
Old 06-06-2010, 11:56 PM   #5
873+3/90zuk
Sweet $64 is right up my alley. Thanks for the help
