Old 06-07-2010, 09:57 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Rebuilding brake calipers removing dust boot
Anyone ever rebuild these themselves?
Doesn't seem difficult at all but I am having a hell of a time removing the old dust boot to install the new one... Anyone have any tips??? Just don't see the point in buying new calipers that are remaned if I can do it myself...
JNJchev77 is offline   Reply With Quote
Old 06-08-2010, 10:04 AM   #2
James McClure
One shot, one kill.
Re: Rebuilding brake calipers removing dust boot
JN, I spent 30+ years working for GM and used to do this for myself until I priced rebuilts from NAPA. At $17 you can't go wrong. I have a set on mine now and they are just fine. If your going to do it yourself anyway, remove piston and then use a small chisel and knock the seal inward at a low angle and the seal will bend and pop out. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 06-08-2010, 10:14 AM   #3
Baron
You have to use air pressure to get the piston out first then you can get the dustboot off. thats the only way they will come off.
and due to this like the other poster said its less hassle to go get the others.
Baron is offline   Reply With Quote
Old 06-08-2010, 12:04 PM   #4
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I just used a flat tip screw driver and got that ring out... I used air to get the piston out, had it out already, just had trouble getting the ring out... I figured for under $5 to rebuild the whole thing was worth it... They were trying to sell me some rebuilt ones for about $40 a pop ... thanks guys!
Old 06-08-2010, 01:17 PM   #5
pseudopimp
pseudopimp's Avatar
can you post pics of the process? i think it would be a cool writeup
84 Scottsdale LWB K10
Rooting against the cowboys is almost as fun as rooting for the GIANTS!
pseudopimp is offline   Reply With Quote
Old 06-08-2010, 01:54 PM   #6
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Unfortunately I didn't take any pics, but I included a link below that was a huge help and should point anyone in the right direction, at least for these trucks ... there are several step by step videos...
Old 06-08-2010, 01:56 PM   #7
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Jim, I will try NAPA next time around, checkers was a bit high to me... thanks again!
