Old 02-15-2003, 04:18 PM   #1
KEH
Better late than never
KEH's Avatar
HELP, Pressure plate to flywheel bolt
I'm not sure which bolts I have to attach the pressure plate to flywheel. (This project has been siiting for 10 years). The Chevy dealer doesn't have any in stock either. The only 6 that I have alike is in the pic below. Is this the correct bolt?
Also, any installation tips would be appreciated. With the non-threaded shank do I just tighten until they bottom out?
It's been a few years, and I want to make sure I get it in right.
Thanks for the help..
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 02-15-2003, 04:20 PM   #2
KEH
KEH's Avatar
sorry, forgot the pic.
Old 02-15-2003, 04:44 PM   #3
crazy longhorn
Fabricate till you "puke"
those look to be the proper bolt, but need a lock washer. here is a link to summit(arp bolts,& pretty cheap) http://store.summitracing.com/partdetail.asp?part=10047 you should also be able to get them in a Dorman @ a local auto parts . the threads dont come all the wat to the top in the flywheel(holes are counterdrilled).....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-15-2003, 04:59 PM   #4
KEH
KEH's Avatar
Thanks CrazyL you're a big help. What is the Dorman that you refer to?
Old 02-15-2003, 05:03 PM   #5
crazy longhorn
Dorman is the brand name, I think i found them @ O Rieleys last time in the perf hardware section . You might also find them in a MR gasket @ a local speed shop. Good luck...crazyL
