Old 02-16-2003, 02:05 AM   #1
ocbaud
Garage Queen Material
answer to my weird spaced tires?
Originally posted by swervin ervin
I'm thinking if you are going with 3" spindles, you should be fine as far as the tire rubbing. This shouldn't change the geometry and throw the camber out so bad it pushes the wheel out. With coils, you end up with negative camber and a lot of shims have to be used to get it back right. This in turn pushes out the wheel and would probably hit the fender lip. But again, I think 3" spindles will be OK. You will probably need to do a little grinding on the lower control arm though. Your 15" wheels are going to rub.
remember how i told you my passanger tires stick out more then my drivers side tires? well i remember that when i got my truck aligned they put about 3 new shims in the pass. side and none in the drivers side.
could that be the reason that tire sticks out so much more? and i still dont know about the back though
ocbaud is offline   Reply With Quote
Old 02-16-2003, 02:12 AM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Yep. Sure is. When they add the shims, it pushes the upper control arm out, thus increasing the track. I've got all the shims mine will hold. My front track is around 2" wider than the back, where stock it's about an inch.
My guy told me, and he is good before I forget, I would be a lot better off with an offset upper control arm shaft. If I go any lower, I'd be out of luck. I'm out of threads on the upper arm mounting bolts. He didn't want to have fewer than at least the whole nut covering threads.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-16-2003, 02:18 AM   #3
ocbaud
so, what can i do to correct this?
Old 02-16-2003, 02:25 AM   #4
swervin ervin
Take it to someone who knows how to properly align a frontend on a dropped truck. I am very lucky to have found the guy who does mine. He is top notch. A lot of places won't touch them because they can't just use factory specs. It takes longer to do it right also. This gets into their time and money they can make. Find a shop who specializes in performance tires and wheels. Most of the time they have a good frontend man. Or they need to have one anyway.
Mike
1985 Chevy C-10
Old 02-16-2003, 02:30 AM   #5
ocbaud
i'll find a good place to align it after i do my poly frontend rebuild. whenever that may be
Old 02-16-2003, 04:52 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I agree with Mike. Take it to a good shop. It cost me nearly twice the price of a regular alignment at the speciality shop I went to. Worth every dime because my truck drives straight and the wheels look properly aligned.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-16-2003, 08:28 AM   #7
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Eric- I think Speedtek in Midwest City does alignment. You might check them out.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-16-2003, 12:37 PM   #8
ocbaud
i'm thinking they do too.i'll probably have them do it, because i know they are very popular at my school, with the ricers
