06-17-2010, 10:09 AM | #1 |
Another Column shift sloppy linkage problem
During my build of my 69 GMC C-1500, I replaced the Steering Column with a re-built CPP unit. I replace the stock linkage with a Kugal unit. The Tranny is a Re-built Turbo 350. So...all components are new. When I first started driving the truck on the street back in May, the shifter was fairly tight and you could feel a slight detent action when using the shifter. Not as much detent as I would like, but acceptable. Now, the shifter has become very sloppy. I've got about 1 inch of play in the linkage. Also, My Neutral Safety switch is not working, I think this also related to linkage slop. Where is the detent plate located? Internal or external to the T-350?
Any thoughts on what the problem may be? Thanks, Dale
1969 GMC SWB FLEETSIDE ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR DALE JONES MY BUILD THREAD: "69 GMC SHORT FLEET" http://67-72chevytrucks.com/vboard/s...d.php?t=388447 |
06-17-2010, 12:56 PM | #2 |
Re: Another Column shift sloppy linkage problem
Anybody?
06-17-2010, 04:06 PM | #3 |
Any takers?
