brake problem
my truck has had a break problem that we thought would be fixed by replacing the master cylinder, putting in new rear drum hardware that wasn't there to begin with (?!), replacing the front disks, etc.
well now the truck stops but you need to basically put the pedal all the way to the floor until it starts working. the drums were cleaned of off roading debris which did help for a short period of time and now it is back to how it always is. everything is spotless and new now, so dirt cannot be the issue i actually did a search a few days ago on here and found a thread with some answers. the thread was about someone thinking they needed to replace their master in order to fix this (dropping a lot of money like me) when it turned out it was something else. now i forget what this something else was and i forget where that thread was at (tried searching again but couldn't find it) if anyone knows what could be wrong with a new master, bled brake lines, perfectly fine drums, and new discs, where the problem is the pedal seems spongy/has to be pushed down all the way (but CAN stop well), or any threads about it, please help thanks... lots of money wasted for nothing (yet) it seems
United States Marine Corps 1986 USMC CUCV M1008 (daily driver) / 1984 Chevy K10 RCLB Last edited by Savage; 06-18-2010 at 01:28 PM. |
Re: brake problem
Did you "bench bleed" the brake master cylinder?
How was the bleed on the system as a whole? (ie, did you seem to get all the air out)? Did you adjust the rear shoes out to the drums after you installed them (the shoes, that is)? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-18-2010 at 02:20 PM. |
Re: brake problem
it really sounds like there is still air in the lines
| Bookmarks |
