Old 06-20-2010, 06:47 PM   #1
mrjones0
95 K1500 bigger tires Speedo
I have a 95 k1500 w/t with a v6 and a 5 speed. I wanna put some bigger tires than the factory 225 75 16's and want to calibrate the speedometer correctly. I have found a couple that say they would only work with the automatic transmission. Anybody have any programmers or solutions that would work?
mrjones0 is offline   Reply With Quote
Old 06-20-2010, 10:06 PM   #2
scotts62
One day...
scotts62's Avatar
Re: 95 K1500 bigger tires Speedo
There is a small computer behind glove box mounted on the HVAC unit, it has about 5 wires going to it i believe. I had to change mine out when i put 3.73's in it, it got the a lot speedo closer but still not exact, mine also has an auto in it.. maybe someone with some better info will chime it but its something to check into. Ill see if can round up some info for you.
Scott
93 crew cab build
Project 62
Old 06-20-2010, 10:27 PM   #3
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
That's the DRAC. Not sure if it's used on the manual.
Maybe do a search on this site?
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 06-20-2010, 10:28 PM   #4
joe231
joe231's Avatar
1995 is not a DRAC (Digital Ration Adapter Controller), it is a VSSB (Vehicle Speed Sensor Buffer), and yes the manual trucks have them also....
check this out....
http://www.tbichips.com/drac/
CHEVY ONLY
Old 06-20-2010, 10:35 PM   #5
scotts62
One day...
scotts62's Avatar
The one i used the one from a 95 in my 92 and it went from 25 mph off to 5 off, least it still reads fast or i would keep the cops busy
Scott
93 crew cab build
Project 62
Old 06-20-2010, 11:58 PM   #6
BIGphillip79
BIGphillip79's Avatar
tires or gear change you don't need to change the vssb you can just have it recalibrated. just google around and you should find something.
If it ain't broke broke don't fix? Get a hammer.
'89 K1500, Reg. cab/long bed, 350/700r4, 285/75-16.
BIGphillip79 is offline   Reply With Quote
Old 06-21-2010, 11:11 AM   #7
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
check this out....
I should have asked my wife before I posted, believe me, she knows everything!
93 Yukon
Old 06-21-2010, 01:05 PM   #8
joe231
joe231's Avatar
I posted a link above with step by step instructions to DIY and it even has a formula to figure out exactly what settings you need.
do I detect a bit of sarcasm there
CHEVY ONLY
Old 06-21-2010, 05:02 PM   #9
mrjones0
thanks i will try to re read the article to make sense of it and figure it out before i get the bigger tires
