Old 06-27-2010, 02:36 PM   #1
treeboy97
treeboy97's Avatar
My front disk brake options
Hello, I have been doing the research and now it's time for a few questions.
I have a stock 1970 C10 with drum brakes. I have been looking at the kits from GMC Pauls and CPP.
I already have drop springs from CPP for the front and back 3" in front 4" in back.
I want to start my conversion in July and have saved enough to do what I want.
Out of those two vendors, in your opinion, which has the better kit?
Can I use the stock front springs and just use a drop spindle instead?
What incidentals will I more than likely need for my disk upgrade?
I have learned allot in the last few months reading here and appreciate what you have to say.
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E
2012 Victory Cross Country Touring
I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time.
treeboy97 is offline   Reply With Quote
Old 06-27-2010, 04:59 PM   #2
70cst
70cst's Avatar
Re: My front disk brake options
http://67-72chevytrucks.com/vboard/s...d.php?t=391083
If all things are equal...GMCPauls
By the way treeboy97... and from Zanesville Ohio. If you can make it we would be pleased to have you join us at the Yellow Springs Vintage Truck 67-72 Chevy/GMC mini meet on August 7th. (see above LINK) We have door prizes lined up and plus if you pre-register you might get a gift from Vintage Truck. Hope to see you there.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-27-2010, 06:52 PM   #3
BIG ORANGE
BIG ORANGE's Avatar
Bought a 69 swb afew weeks back for my son and run up on a 72 lwb fri. so I'm gonna swap out the front carrier for the disc brakes and cut 1 round out of the springs for a 2" drop and then swap out the rearends and fab up a set of 2" blocks for a 2" drop in the rear, run 255/70/r15 tires for a nice lowered look for cheap..........
Best of luck!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 06-27-2010, 10:19 PM   #4
junkyardjohn
junkyardjohn's Avatar
I LIKE TO TAKE A WHOLE FRONTEND ASSY OUT OF ANY DONOR FROM 73-86. MORE ASSY.s FROM OTHER YEARS MIGHT BE A PERTY-NEAR BOLT IN AFFAIR.. I'VE JUST NEVER PERSONALLY DONE IT & I KNOW THESE WORK. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-28-2010, 09:49 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I installed the disc brake upgrade kit from Early Classic Enterprises (earlyclassics.com) and wouldn't have gone any other way.
Also... just an FYI, keep in mind that the rear ends available in 1970 varied as one was narrower than the other. When you add disc brakes to the front track width is widened by .75" on each side which might cause issues with your current wheel/tire combo.
IMO... with the two vendors listed above I would check with GMC Pauls vs. CPP... refer to the review section of the board for other issues experienced by fellow board members. (I have never ordered from them, just reviewed the experiences felt by others.)
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
