Finished body work/primer, dropped in engine/trans (both rebuilt) finally feeling confident on progress , removed dash cluster only to find a _rapy wire harness
install! (Ms.Smith 1st.grade class work) Another mountain- advice & help appreciated |
One day...
Re: EZ Wiring , how easy?
Welcome from OKC! They are not too bad just take your time and route them where you want them before you cut.
Used E-Z wiring on mine and it wasn't too bad. Wires are labeled well but you will have to solder on some terminals. I had to engineer a way for the wires to go through the cab because there is no bulkhead connector. I haven't had any problems since I put it in though.
