Old 02-17-2003, 06:00 PM   #1
Dropt72Shortbed
Dropt72Shortbed's Avatar
whats this for on the brake pedal?
theres a shaft that the pedal assembly is on, to the outside theres this braket that swings 360degrees and pretty much looks like its doing nothing at the moment. whats it for? and how do remove this whole shaft with the braket on it?
Dropt72Shortbed is offline   Reply With Quote
Old 02-17-2003, 06:01 PM   #2
Dropt72Shortbed
view from underneath
Old 02-17-2003, 06:07 PM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
That was for a clutch. Your truck was a stick at some point in it's life.
jmanz69 is offline   Reply With Quote
Old 02-17-2003, 06:08 PM   #4
67pro-street
67pro-street's Avatar
its for your clutch linkage if you have a stick shift truck.
67pro-street is offline   Reply With Quote
Old 02-17-2003, 06:12 PM   #5
Dropt72Shortbed
yea the truck used to be a 6cyl 3spd. i was wondering what it was doing there as it seemed to serve no purpose
Old 02-17-2003, 06:14 PM   #6
crazy longhorn
Fabricate till you "puke"
Just unbolt it & pull it out.....it serves no purpose if you have an auto trans(the brake peddle will stay in place on a hollow tube )....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-17-2003, 07:45 PM   #7
67cst
i love summertime
67cst's Avatar
has anyone ever gone from a 3spd pr 4spd to auto? i am and my brake and throttle are so close together, has anyone moved the brake over or do you guys usually leave them
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 02-17-2003, 07:45 PM   #8
VDOG
Grand PooBaa Member
VDOG's Avatar
Did you keep the same rearend when you change engines?
Im in Gardena, got any spare parts?
VDOG is offline   Reply With Quote
Old 02-17-2003, 07:53 PM   #9
knucklebuster
Failure is NOT an option!
knucklebuster's Avatar
good question 69cst i'm doing the same and haven't thought about the closeness of the pedals
House payment or truck parts?????.........why does life have to be so complicated?
1969 Chevy Shortbed Fleetside
1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto)
1990 Ni$$an hardbody( daily beater that has been really beaten!)
1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me)
knucklebuster is offline   Reply With Quote
Old 02-17-2003, 10:03 PM   #10
Dropt72Shortbed
i didnt do the swap, some previous owner in the past must have done it. rear end is a 12 bolt 3.73 posi no way to tell if its original or not, my glove box options sticker was removed when the dip**** previous owner painted the truck himself.
Old 02-17-2003, 10:58 PM   #11
slam33
slam33's Avatar
I did the stick to auto and left the brake where it's at. I don't think there was a differant pedel for autos.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 02-18-2003, 09:39 AM   #12
smokekiki
Mike
smokekiki's Avatar
I moved my pedal over about 3in by heating near the top of the arm,bend to the left,and then heat near the pedal to make the pedal strait.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
