Old 07-06-2010, 02:23 AM   #1
Hoffman65burb
Hoffman65burb's Avatar
frame cracked..
Well, the other day my buddy was looking over my truck, turns out the frame is cracked about 5 inch's by the powersteering box, I would have never noticed it as it was behind the box. So time to tear it down... Plan is to strip it all and get it ready to have it repaired. I know a guy that has done many of these
This common on these trucks? Any of you had this happen? Any pictures of the repair?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 07-06-2010, 02:48 AM   #2
Chionos GMs
Chionos GMs's Avatar
Re: frame cracked..
I think it is common on these trucks
My last name is Chiono pronounced key-ono even if my grammar teacher told me Ch dont make a K sound
1995 Ext. cab 350 4wd dd 260,*** miles
1986 1/2 ton swb 305 2wd (melted bearings) SOLD!!
1982 3/4 lwb 6.2 diesel 2wd
1962 Chevy 283 4 speed long step 2wd 2 OWNER GONE!!
Chionos GMs is offline   Reply With Quote
Old 07-06-2010, 06:13 AM   #3
MONTEZ
Re: frame cracked..
Very common on these trucks. Especially the 4x4 and trucks with wider tires. It's because the pitman arm is on the same side as the steering box and creates too much pressure on the frame near the steering box. If you wanna fix it right and not have to worry about it again, put the crossover steering from like a 91 suburban on it.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 07-06-2010, 10:36 AM   #4
Prerunner1982
Prerunner1982's Avatar
Re: frame cracked..
Very Common... even happened to my 2wd.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-06-2010, 10:44 AM   #5
chrismoore701
chrismoore701's Avatar
Re: frame cracked..
I had this happen on my '79 stepside 2wd. I just ground a grove along the crack with a carbide bit and welded a bead over it and ground it down. back in business, at least I hope
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 07-06-2010, 11:01 AM   #6
MONTEZ
Re: frame cracked..
You may want to consider welding a plate to the frame, more than likely it will crack again.
Old 07-06-2010, 12:04 PM   #7
silvereagle07
silvereagle07's Avatar
Re: frame cracked..
It's a common problem with these trucks. Autofab makes a gusset kit to reinforce the frame. Check it out.
http://www.autofab.com/sbgk%20100.htm
Good article here.
http://www.4wheeloffroad.com/brandpa...ame/index.html
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 07-06-2010, 12:09 PM   #8
benoit454
Chris
benoit454's Avatar
Re: frame cracked..
jcwhitney sells a precut and drilled kit that welds back in over the crack.
Personally never had one break, but bought a truck that was 2wd with one already broke. I'd weld the crack up, plate it inside and out and weld the guts out of it all.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-06-2010, 12:40 PM   #9
Prerunner1982
Re: frame cracked..
Offroad Design also offers a brace.
http://www.offroaddesign.com/catalog/steeringkit.htm
Jon
Oklahoma Roll Call
