Old 07-07-2010, 12:12 AM   #1
Berndtc426
Berndtc426's Avatar
Pitman Arm Question
So I searched the sight and found a few threads about what pitman arm to use for crossover steering. But what I didn't find were 2 answers that were alike. So here's my question...On my 72 GMC with a dana 44 front axle I want to install crossover steering. I've pieced a kit together but can't seem to figure out what pitman arm to use with the 2wd drive box I have. I have approx 7 inches of lift. I've heard that I can use a ford bronco arm, but no one was specific on what years would work. If anyone can tell me which pitman arm will work for me, or point me in the direction I should be looking I would appreciate it.
Berndtc426 is offline   Reply With Quote
Old 07-07-2010, 12:49 AM   #2
1tonswb
1tonswb's Avatar
Re: Pitman Arm Question
Ive used pitman arms from dodges, fords and jeeps. There are alot of arms out there that will work. The bronco arms I have used in the past are for a 78-79 bronco. Ive used the superlift drop arm on my truck with 6+ lifts. If your using GM dranklink ends then you will have to ream out the tirerod hole in the bronco arm.
Other arms I have used are skyjacker arms for 94+ dodge rams. The taper is the right size but the indexing is just a bit off. Even so, they have more drop that the superlift bronco arms and the indexing being off by 1 tooth isnt enough of a noticable differance. Its the number one arm I use whenever Im building crossover systems. Hope that helps.
1tonswb is offline   Reply With Quote
Old 07-07-2010, 11:10 AM   #3
Berndtc426
Berndtc426's Avatar
Thats just the kind of info I was looking for. Thanks!
Old 07-07-2010, 03:02 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Wagoneer arms work too.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-07-2010, 08:16 PM   #5
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Jeep TJ arms work too
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
crossover steering, dana 44, pitman arm
