Old 07-07-2010, 11:29 AM   #1
my69camaro1
Young One
How to change? AC Clutch Fan 2006 Chevy 2500
This is on one of our shop trucks with 150,000mi.. Stock clutch fan on compressor has melted rubber ozzing out of it and trucks ac doesn't blow cold.. Was working yesterday morning then made noises at lunch and stopped working.
How do I change this? Never messed with anything involving AC parts before.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
my69camaro1 is offline   Reply With Quote
Old 07-08-2010, 10:15 AM   #2
clinebarger
Re: How to change? AC Clutch Fan 2006 Chevy 2500
You mean the compressor clutch? If the clutch bearing was bad it whould throw the belt. Sounds like the compressor itself is locked up. If it is you will need to replace the compressor, dryer, orifice tube, Flush the system along with the proper amount of oil & freon.
Total oil capacity 7.1 ounces
Total refrigerant capacity 1.6 lbs.
clinebarger is offline   Reply With Quote
Old 07-08-2010, 08:41 PM   #3
truckdude239
truckdude239's Avatar
replace the ac compressor
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-13-2010, 03:08 AM   #4
finch
finch's Avatar
I didn't think the new trucks had orifice tubes? thought they were all switched to TXV systems by now. but last I checked a compressor clutch cost about twice as much as a whole reman compressor. I really don't think you'd have to put a dryer on it if the system is sealed still. if it has no refrigerant in it then you should look at putting a dryer in and compressor. vac it down and put in your oil & dye, then charge it up and check for leaks.
Andy...
'70 C/10 Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=298553
'71 K/20 Frame-off resto, SOLD!!!
http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12
'05 Silverado Z-71, CC SB, Daily Driver
finch is offline   Reply With Quote
Old 07-13-2010, 10:06 AM   #5
clinebarger
They still use orifice tubes. I think his compressor is locked up, So I whould change the dryer Along with flushing the condensor, evaporator & lines, Its not worth taking a chance.
