Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-13-2010, 04:40 PM   #1
dutsuno
72 lb battery killer
bought a brand new battery. it died within 24hrs. didnt evn hav enough juice to turn the lights on. this is the 3rd battery ive gone thru. any suggestions on y it is sucking power while the truck is off??? thanks guys!
dutsuno is offline   Reply With Quote
Old 07-13-2010, 05:31 PM   #2
raycow
Re: 72 lb battery killer
Does your horn work normally?
Ray
raycow is offline   Reply With Quote
Old 07-14-2010, 06:02 AM   #3
dutsuno
no the horn does not work. but i have a battery charger that has an alternator checker. n it gave me a code that read the alt. was bad. could the horn relay b causin it to do that?
Old 07-14-2010, 07:17 AM   #4
truckdude239
truckdude239's Avatar
the diodes in the alt could be bad pulling off the battery when they truck is off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-14-2010, 09:49 AM   #5
fixit-p
fixit-p's Avatar
You have a key off drain follow this thread to test http://67-72chevytrucks.com/vboard/s...ad.php?t=33198 the previous two posters named some common key off drains so as part of the test also unplug the horn relay and alternator.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-14-2010, 12:44 PM   #6
raycow
Then there is a good chance that this is where your problem is. Disconnect the plug-in connector at the relay and see if the drain stops. The relay itself likely isn't bad, but the wire going from the relay to the steering wheel could be shorted to ground at some point, causing the relay coil to draw power all the time. If the relay feels warm when you touch it, this is a sure sign.
Ray
Old 07-14-2010, 11:41 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if the machine says your alt is bad... I would start there.
While the engine is running, and not charging the battery, then you are running directly off the battery and running it down, untill it is dead.
Old 07-25-2010, 06:31 PM   #8
dutsuno
k . i took a volt meter to my alt. its charging the battery. but ther is still a drain. any ideas fellas??
Old 07-25-2010, 11:07 PM   #9
Longhorn Man
what was it charging at... 12.5, or 13.5?
Old 07-26-2010, 02:33 AM   #10
dutsuno
i believe it was higher round 14.5. ill have to check it again to b 100% sure
Old 07-26-2010, 02:39 AM   #11
raycow
Have you tried unplugging the horn relay yet? I'm not saying that's the only possibility, but it sure won't cost you anything to try it.
Ray
Old 07-27-2010, 04:15 AM   #12
dutsuno
no. because i thot it was the alt. but ill give it a go tomorrow. do i unplug all three wires? i believe thers a black ,red, green???
Old 07-27-2010, 06:32 AM   #13
Longhorn Man
its a single plug, they'll all three come off together. Listen for a click insude the relay as you unplug it. If it cliks, then you found the problem.
Old 07-28-2010, 06:22 PM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
If your alternator is good and charging your battery then you got a serious power drain some wheres in your system. You gotta stuck going through everything I would start with simple stuff first and go from there. Do you have an aftermarket stereo stuff or light stuff in your truck that is wired to a constant hot?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
battery
