WIW 71 2wd blazer
Im not sure if this is where this belongs, if not please move it. I am considering selling my factory 2wd blazer. It is a 71 on air bags (not plumbed but do have all fittings and lines to use shrader valves). The engine is an 01 5.3 (30K miles) with a comp big mutha thumpr cam, ls6 springs and it is tuned. It also has a 4l80e with a 2500 stall. The transmission is in but not fully installed. I have the shift linkage, flexplate and spacer to complete installation. It also has a new gas tank, walbro fuel pump, hooker headers, new brake booster, master cylinder, prop. valve,and rear disk brakes. I had started installing a step notch in the rear but so far I have only cut the floor to clear the notch (which I cut down to only raise the floor 4" so I could keep the rear seat), the frame is untouched. I have many new in the box parts including new autometer gauges in a new bezel, new rockers, rear floor section, rear cross brace, new tailgate, new rocker box for the drivers side, uncut ac dash, and im sure some other stuff. There is a little rust in the rear floor section and the drivers side floor which I had started to repair but never finished. I also have rack and pinion for a drop member I would include. Im not certain I want to sell it and have no idea what it would be worth. So what is it worth?
| Bookmarks |
