Old 07-20-2010, 11:19 AM   #1
hoss67
hoss67's Avatar
Sway bar help
I need a front sway bar for my 1967 C10. Didn't come with one from the factory. I have a local pull it yard an they have some 73-87 chevy trucks c10-c30's. Was wondering if they would work on my truck. If so, what kind of modifications will I have to do. Thanks
hoss67 is offline   Reply With Quote
Old 07-20-2010, 11:55 AM   #2
marks1972
marks1972's Avatar
Re: Sway bar help
hey hoss. dont know how much work it going to be but i did do some reserch for you. i looked up both swaybars in LMC and the one for the 67-72 has the same part number as the 73-86. there is also a performance swaybar kit(complete) in there and they are both the same.
part # 34-0162 swaybar
part # 34-2510 performance swaybar kit
hope that helps ya. at least you know they are the same.
by the way
I did stay at a Holliday Inn Express last night
had to throw that in
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline   Reply With Quote
Old 07-20-2010, 12:05 PM   #3
hoss67
hoss67's Avatar
Re: Sway bar help
Thanks I will check on that.
Oh yeah, hope you sleep good at the Holiday Inn Express. LMAO
Old 07-20-2010, 12:11 PM   #4
marks1972
marks1972's Avatar
Re: Sway bar help
why i did thanks for asking.
by the way. where is Harrisville.
Mark
U. S. Navy Seabee
Old 07-20-2010, 12:15 PM   #5
63chevyll
gets board easy.......
63chevyll's Avatar
Re: Sway bar help
if you can get a sway bar from a 2wd dually up to 1992 or even a 3/4 ton van
they are 1 1/4 inch and work damn good,
buy the right bushings and your done
BTW, are you running lowering springs or are you at stock hieght
63chevyll is offline   Reply With Quote
Old 07-20-2010, 12:25 PM   #6
dfwright
dfwright's Avatar
Re: Sway bar help
It will work, but you'll need the mounting brackets that are riveted to the frame, if yours didn't come with them. You'll need to have tools to drill out or cut off the rivets to get the brackets.
I just bought a pair of brackets from a member here, and got my bar off a 1980 truck from the pick-n-pull
As far as modifications, I had to remove 2 rivets from the very front cross-member to mount the brackets - all the holes are there.
There's a great write-up in this faq: Swaybar Install FAQ With Pictures
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 07-20-2010, 12:38 PM   #7
hoss67
hoss67's Avatar
Re: Sway bar help
Cool good. Thanks for all the replies. I will check an see at the pick an pull yard. I guess I will be spending awhile there. LOL
BTW marks1972 Harrisville is 2 1/2 hours north of you up Hwy. 49.
Old 07-20-2010, 03:17 PM   #8
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Sway bar help
67 - 87 chevy or GMC trucks sway bars will work. The pain is having to chisel or drill out the rivets for the frame mount brackects. (or you can buy new ones from EarlyClassic)
Look for 3/4 or 1 tons for thicker sway bar. Your lower A-Arms will already have the needed bolt holes for the bracket at the end of the bars.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 07-20-2010, 04:28 PM   #9
BIG ORANGE
BIG ORANGE's Avatar
Re: Sway bar help
Check the parts board, I just bought 1 from blue_69 for 20.00 bucks plus ride.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-20-2010, 04:39 PM   #10
capev86
Re: Sway bar help
the LMC truck bar is only 1-1/8" diameter, so you pay more for less. I'd have gone this route last year instead of buying my sway bar from CPP which is 1-1/4 and bolts in but uses end links which get close to hitting the tie-rod adjusters.
capev86 is offline   Reply With Quote
Old 07-20-2010, 05:08 PM   #11
hoss67
hoss67's Avatar
Re: Sway bar help
I think I might have found one off of a 72 said it was an 1 1/8 diameter an comes with all the hardware doesn't want too much for it. Probably the route I will go. I appreciate all the replies on this matter.
Old 07-20-2010, 09:22 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Sway bar help
how much diff. will the larger diameter bar have (handling) I added a 1 1/8 bar and was quite happy!
John
1999 Toyota Tacoma 4x4
Old 07-20-2010, 09:31 PM   #13
63chevyll
63chevyll's Avatar
Re: Sway bar help
I realy liked the 1 1/4 bar,
As far as the frame brackets, if you have lowered or cut coils just mount the sway bar right to the frame.
the angle of the control arms make this possible
Old 07-20-2010, 09:44 PM   #14
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
Re: Sway bar help
I just mounted mine tonight and didn't grab the frame brackets from the donor truck, an 85 1/2 ton 2wd. I had to drill the holes for the frame bushings but the control arms already had the holes. However, mounting it to the frame, I rub my pitman and idler arms when turning and slightly on straight ahead so i am going to get some new frame brackets from work (I work for a GMC dealer), so the bar will sit lower and clear the steering linkage. I definitely feel the difference in the way it rides and turns as it is though. Why didn't I do this 2 years ago???
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 07-20-2010, 09:49 PM   #15
Rat Bastid
Rat Bastid's Avatar
Re: Sway bar help
awesome thread firefighter,wattched your whole sway bar tutorial and felt completely capable of doing this....i was lucky enough to have a sway bar come with my rig and plan on lowering it so will come in handy....thank you sir
Rat Bastid is offline   Reply With Quote
Old 07-21-2010, 12:34 AM   #16
63chevyll
63chevyll's Avatar
Re: Sway bar help
the frame brackets hang down too much for me,
maybe shim them 1/4 or so???? just a question
Old 07-21-2010, 11:28 AM   #17
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Sway bar help
I put a 1 1/4 inch bar from a wrecked 80's Camper Special truck with new polyurathane bushing and the special brackets for lowered trucks from ECE on my long box big block truck about 5 years ago and IMHO its the best value handling upgrade you can do to one of our trucks. If you have been driving your truck for while you will notice the difference in the first mile of driving after the install. One tip, I'd spring for new bushings.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-21-2010, 06:53 PM   #18
bobbo
bobbo's Avatar
Re: Sway bar help
Thinking I am going to try to shim them since the new brackets are $27 each and I just can't justify that kind of money. I could probably get them from a junk yard but, as already said, they are riveted and would be a bit of trouble getting them off. I do agree that they do hang down fairly low with all the factory brackets, so shimming is the plan.
Robert
Life Member
1969 1500
Norwood, MO 2007
Old 07-21-2010, 10:32 PM   #19
oldblue1968chevy
Re: Sway bar help
I did this mod a few weeks ago, very helpful TX writeup was...I dont think he gets on anymore, too bad a very knowledgable guy!
John
Old 07-21-2010, 11:15 PM   #20
Jwill41
Jwill41's Avatar
Re: Sway bar help
the rivets aren't too tuff if you use a large chisel and a large hammer.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-21-2010, 11:28 PM   #21
oldblue1968chevy
Re: Sway bar help
lol they killed me and i had powertools my arms were aching!
John
Old 07-21-2010, 11:49 PM   #22
leddzepp
Moderator
leddzepp's Avatar
Re: Sway bar help
Make an "X" on the head of the rivet with a cutoff wheel. Then use an air chisel to pop them off. I got it down to about 20 secs each.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-22-2010, 12:06 AM   #23
dan42
dan42's Avatar
Re: Sway bar help
Just grind them down and pop them out with a hammer. It's a piece of cake.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
