Old 07-22-2010, 10:46 AM   #1
chevymotocross
chevymotocross's Avatar
Calipers not installing on Western Chassis spindles
I'm so close to getting this truck on the ground but ran into an issue. My calipers will not fit between the castings of the spindle. These are 1'' rotors and I did order the right spindles. Is minor grinding necessary? It's just a tad too much material so it's not allowing the caliper to slip in.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 07-22-2010, 10:54 AM   #2
Jonboy
Slots go on anything!
Re: Calipers not installing on Western Chassis spindles
Just give them both a little love. I had to clearance my spindles a little bit because they were hitting the control arms at full lock when turning. No big deal, just a little work with the die grinder and done.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-22-2010, 10:55 AM   #3
ERBSIX
ERBSIX's Avatar
This might be a dumb question, but aren't you supposed to compress the "boot" with a board before putting the caliper on?
That might be the issue...?
78 Silverado 1/2 Ton LWB (restore)
78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse)
My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128
Ellis Benus - Web Design Columbia Mo & Google Fan Boy!
ERBSIX is offline   Reply With Quote
Old 07-22-2010, 11:17 AM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
When installing new pads, yes, usually the piston needs to be pushed back into the caliper.
But it sounds like it is a clearance issue between the caliper and the casting on the spindle. I agree with JonBoy, the casting probably just needs cleaned up. Hit the spots where the interference is lightly with a good bastard file or die grinder a little at a time until there is a good fit. Maybe even on both parts.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-22-2010, 11:25 AM   #5
silvereagle07
silvereagle07's Avatar
Do you have any pics of the problem areas? Just curious.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 07-22-2010, 12:44 PM   #6
chevymotocross
Got them installed. I compressed the pads a tad more, and with a little hammer tap they went on. Truck is LOW. Pics to come after my trip to the alignment shop.
Old 07-22-2010, 12:46 PM   #7
ERBSIX
ERBSIX's Avatar
Sweet! Can't wait for pics!
Old 07-22-2010, 03:48 PM   #8
Acrophobia
Acrophobia's Avatar
Yes pics are a good thing!
Acrophobia is offline   Reply With Quote
