Old 08-02-2010, 11:30 AM   #1
a5Ben
The Question: S10 or No S10
I'm still laying out the plans for my 49 3600 and wanted to get some opintions ( I know there are many)
I am down to three plans for the truck.
#1.
Weld in an IFS (Scott dansforth) with S10 suspension
Swap rear end
drop in a 350/700r4
#2
MustanII front end
Swap rear end
drop in a 350/700r4
#3
Put the body onto an S10 rolling chassis
Add spacers to the rear end or swap it
drop in a 350/700r4
For option #3 I have located a 97 extended cab short bed rolling chassis for $275 with wheels/tires, all suspension, gas tank and steering column. Right now I'm leaning towards this option because I think I can get the truck on the road faster but I wanted some ideas from those of you have been through this a time or two.
Thanks!!
Ben in SC
a5Ben is offline   Reply With Quote
Old 08-02-2010, 11:54 AM   #2
av8tr33337
av8tr33337's Avatar
Re: The Question: S10 or No S10
I'm in the same boat as you. I just picked up a rolling 94 S10 chassis for 75 bucks. Being a laid off aircraft worker, money, or lack there of was my main motivation for going this route. The other two options you listed would eliminate the need for spacers and make the build more strait forward but if you have a little ingenuity and fabrication skills I think the S10 option would be equally satisfying. Break lines, fuel lines, gas tank already in place. Easy to find reasonably priced parts. Lots or lowering products out there if you like the low look. I am no authority on the subject but I think it's a good way to go.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 08-02-2010, 11:58 AM   #3
a5Ben
Wow, I wish my deal had been that good...... Actually I havent bought it yet so I may still look around, did you call junk yards or find it from an individual?
Ben
PS, I do like and want the low look.
Old 08-02-2010, 11:58 AM   #4
mr48chev
mr48chev's Avatar
Personally I like the stock frame with an independent crossmember added along with changing the rear suspension. One primary reason. It is a heck of a lot easier to get all of the body parts lined up like they need to be and not have it look off kilter.
But there is a lot to be said for buying a complete chassis to go under the truck for 250 and having a rolling truck in a weekend's worth of work and the time and expense (which isn't much) that it takes to build a set of brackets/mounts that one of our members designed and was kind enough to offer up for us to use.
I have a copy of his design but don't seem to have the link to that thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=311681
http://www.jalopyjournal.com/forum/s...ead.php?t=8491
I'd probably want to swap to an S-10 4x4 rear end so as not to have to use the spacers though.
Old 08-02-2010, 01:45 PM   #5
av8tr33337
av8tr33337's Avatar
Well I did actually have to hunt down some rear springs (25 bucks) and shackles (15 bucks). I got the springs from one guy and she shackles from another. Funny thing was, the shackes were the ones that originally came off the truck. This kid said his uncle was the one who baught the rear springs off my S10. So I guess all in all it cost me 115 bucks. But I did get a spare S10 rear end 2WD as well as the one it was rolling on, and a gutted extended cab in descent shape (hope to get a few bucks out of all this stuff)
av8tr33337
1951 3100 Pickup
Old 08-02-2010, 02:00 PM   #6
Thadious
Currently working with the S10 swap myself.
Keep in mind that in using the 4x4 rear end, you will still want to play with the backspacing on the rims. Most of us are finding that 8" is the widest rear you will want to play with, with about 2 1/2" - 3" backspacing on the rears and about 2" - 2 1/2" on the front. This will alleviate the requirements for spacers and give a fairly old school deep dish look.
And yes, having the availability to walk into any Napa or Jim Bob's auto store and find any engine / chassis parts you're looking for... on the shelf.... priceless
I paid $400 for my s-dime and traded some sheet metal for the 4x4 rear ($100) and sold the seats for $150 so really... was only into it for $150 which gave me a rolling / running chassis... pretty cheap IMO but I still opted to rebuild and redo all the brake lines, rotors, pads and freshen the engine. After all, MUCH easier to do with the body off!
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 08-02-2010, 03:59 PM   #7
jeffs51chevy
jeffs51chevy's Avatar
a5Ben,
I can only speak to the s10 swap. The cab mounts mr48chevy was talking about was what I came up with after realizing this hobby takes real money. You can check my thread out if you like, http://67-72chevytrucks.com/vboard/s...d.php?t=294539 The link he posted will get you started, but the cab will sit pretty high. All in all, I'm very happy with how it has all turned out. It goes to show that even a guy with no experience can go this route. If you have questions, fire away.
Good luck,
Jeff
jeffs51chevy is offline   Reply With Quote
Old 08-02-2010, 04:01 PM   #8
a5Ben
Jeff,
I read your thread start to finish. Did you wind up having to raise your bed up any? My bed currently has a steel floor welded in that I plan/hope to remove and return to wood. I have pretty decent welding skills so I should be able to make up the mounts. I too am working on a small budget so anything I can do myself cheap is a PLUS!
Thanks,
Ben
Old 08-02-2010, 04:20 PM   #9
jeffs51chevy
Ben,
I ended up raising the bed floor 1 3/4. 2 inches would be best because I had to tweak a few things to make it all work. Budget wise, I'm into this thing (including engine machining) a $1.99 less than 3 grand (give or take). I think my budget is fantastic, but my wife, not so much. I've had a blast with it and my kids have to. It's been one of the most rewarding projects, even if it takes me 10 years to finish. I will help as much as I can.
Jeff
Old 08-02-2010, 05:09 PM   #10
av8tr33337
av8tr33337's Avatar
Im thinking of using an 84 camaro rear that measures 60 in.
av8tr33337
1951 3100 Pickup
Old 08-03-2010, 03:42 AM   #11
raycow
Is that 60" measured over the wheel mounting surfaces?
Ray
raycow is offline   Reply With Quote
Old 08-03-2010, 08:48 AM   #12
av8tr33337
av8tr33337's Avatar
Yes I believe so, I got the measurement off a website. I can measure it myself in a few days. Need some time to get stuff re-arranged in the shop. Isn't that a couple inches wider that the s10 4X4??? or close to the same??
av8tr33337
1951 3100 Pickup
Old 08-03-2010, 10:28 AM   #13
mobileortho
mobileortho's Avatar
Bartman, what happened to your half ton swap?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 08-03-2010, 11:57 AM   #14
raycow
It's about right for the S-10, but it sounds too narrow for the Camaro. That's why I asked how the measurement was taken.
Ray
Old 08-03-2010, 06:34 PM   #15
a5Ben
This might help:
http://www.carnut.com/specs/rear.html
Ben
PS, I pick up my rolling chassis this weekend. Now to collect parts to mount a 350 on it!
Old 08-03-2010, 06:53 PM   #16
Warrens69GMC
Warrens69GMC's Avatar
The camaro measures 60.5" wms to wms - The problem is when you start to add power to it, (the 7.5" or 9 bolt) it tends to break. The camaro guys break it with a 170hp 305 and sticky tires!!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-03-2010, 07:01 PM   #17
LEEVON
Moderator
LEEVON's Avatar
camaro 8.5 fits nicely at about 60.5 or 61", plenty strong. I see them with posi and desirable gears (3.42, 3.73) from $200 to $400. I picked up a good 3.73 unit for $250 and it fits like a glove.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-03-2010, 07:14 PM   #18
Warrens69GMC
Those are 1970 to 1981 rear ends.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-03-2010, 07:24 PM   #19
av8tr33337
av8tr33337's Avatar
Mine is an 84 camaro rear end I believe a 10 bolt. Will possibly find time to check it out tomorrow. 109 degrees here in Wichita Kansas. Got to get out there early tomorrow.
av8tr33337
1951 3100 Pickup
Old 08-03-2010, 07:25 PM   #20
mr48chev
mr48chev's Avatar
Thanks for posting the info and the link Jeff. Your instructions an plans make it fairly inexpensive and easy for a guy to do the swap and have it right.
Old 08-03-2010, 09:50 PM   #21
Dan Bowles
AD Addict
Yep, Camaro is fine. Ditch the 4x2. It is too narrow and the 4x4 still needs spacers. What are you "collecting" to put the 350 in it? All you need is a pair of motor mounts and some steel plate. If I were to do it again (and I will...) I'd slot the frame to take the steel plate, mount the engine to the plate, fit it where I wanted it, and weld the plate into the frame.
Dan Bowles is offline   Reply With Quote
Old 08-04-2010, 08:41 PM   #22
av8tr33337
av8tr33337's Avatar
Did some work on my S10 frame today. Cut the front frame horns back and cut all the cab mounst off. Got the Camaro rear mocked up. I measured the Camaro rear end and it measures 61 5/8 mounting surface to mounting surface with the drums on. I did a lot of measuring. The distance between the rear tires is currently 53 inches. The bed is 50 inches so I should have 1.5 inches between the tires and bed. The rear fenders look to be 12 inches deep so I should be able to run 8 inch and probably to 10 inch wheels with no problem. Will need to be mindfull of backspacing etc.
av8tr33337
1951 3100 Pickup
