motor mounts
can i use the factory mounting brakets that came off my 77 chevy on my 62 or do i have to order after market ones? by the way im going to run a 454 if that matters.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: motor mounts
Yes you can use the '77 motor mounts and brackets. However on the frame brackets you will need to add a spacer on top of the frame since the '62 frames are shorter than the '77 frames.
Re: motor mounts
ok thanks. will my trans clear the fire wall with the motor sitting up that high?
Re: motor mounts
it depends on which trans that you are using and which centre hump that you have
ron Last edited by padresag; 08-06-2010 at 10:01 AM. |
Re: motor mounts
im not sure what trans yet. im just buying one thing at a time and im trying to get the body put back together.
60-66 Nut
Re: motor mounts
The spacers don't really move the engine up very much if at all. It is more so compensating for the difference in the frames, like I mentioned. You did convert to the '73-'87 front crossmember and suspension didn't you?
Re: motor mounts
yeah i got one out of a 77 gmc
