Old 08-06-2010, 02:29 AM   #1
Frijolito1988
Disc Brake questions
Guys I have a couple of questions in regards to disc brake conversions. Today me and my dad picked up a complete 5 lug disc brake off a 71 truck.
- My question I believe the guy said it came off a 3/4 ton or 1 ton truck , BUT its a 5 lug , arent all 5 lug disc brakes from 71-72 off 1/2 ton trucks ? If it did come out of a 3/4 or 1 ton will it fit my C10 ?
- It came with everything needed minus the master cyclinder.
What other parts will I need to properly install these on my 68 C/10 , to convert from 6 lug drum , to 5 lug disc. Will I only need the tie rod ends ? If so can anybody direct me in the right location wehter it be from classic industries or autozone/kragen ?
Much appreciated !
Frijolito1988 is offline   Reply With Quote
Old 08-06-2010, 07:50 AM   #2
cdowns
cdowns's Avatar
Re: Disc Brake questions
you will need new proportioning valve for a disc/drum system
Old 08-06-2010, 10:30 AM   #3
Frijolito1988
Aside from the proportioning valve , all I would need is the outer tie rod ?
Old 08-06-2010, 11:27 AM   #4
Frijolito1988
Another question. Can I use the same Brake Booster and just change out the master cylinder / proportioning valve ?
Also when buying tie rods, so i buy both the inner tie rod and outer, or only the outer tie rod ?
Old 08-06-2010, 12:22 PM   #5
Frijolito1988
Found this great write up
http://www.customclassictrucks.com/t...all_joint.html
has everything pretty much step by step.
I still have a few questions though.
As far as the tie rods go , do i only have to replace the outer tie rods that go attached to the spindle or both of them ? Also I only change the upper ball joint or do I need to replace the bottom one as well ?
Old 08-06-2010, 03:07 PM   #6
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I gather, your 68 C/10 has 6 lug drums all the way around. I have a 69' Step Side and it had 6 lug Drums and I converted to a 5 lug setup from a 71. There was a power brake booster in the truck already. I used that and it works just fine. As far as other stuff to make the change over, Cdowns has already mentioned the proportioning valve and yes the Master Cylinder. You also mentioned you were going to get tie rods. It's real simple, if your going to convert your front end to the 71 5 lug/disk brakes, buy the parts as if you were buying them for the 71. So when going to Autozone/Napa (I went to Advanced Auto) Tell them you need parts for a 71 not a 68. I ordered both new inner and outer tie rods and ball joints.
ALSO.........If there is a drag link on that 71 setup, TAKE IT because the taper on the 71 is different than the 67-70.
P.S. Your Brake Line routing will also change
With the right parts, it was a very smooth and easy change over
we did it in a weekend
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 08-06-2010, 03:11 PM   #7
Frijolito1988
Thanks!
So today im going to buy the inner and outter tie rods , master cylinder, proportional valve. As far as ball joints go, do i only buy the top ones or bottom ones as well ?
Old 08-06-2010, 03:22 PM   #8
swierker
swierker's Avatar
Originally Posted by Frijolito1988 View Post
Thanks!
I would say why not replace the bottom ones if you are going to have it apart anyway.
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 08-06-2010, 03:24 PM   #9
my67chevytruck
Under Construction
my67chevytruck's Avatar
i would buy lower and upper balljoints. you might as well do it right now, versus tearing it back down later.... if you can get MOOG brand parts get em......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-06-2010, 03:26 PM   #10
myoldchevytruck
x2....replace them
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 08-06-2010, 03:29 PM   #11
myoldchevytruck
How about that drag link? Are you able to get that from that 71 setup?
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 08-06-2010, 03:39 PM   #12
Frijolito1988
Thanks guys im definately going to go ahead and replace upper and lower. Another question. by drag link is that like the front swaybar ? If so i do not have that part. That is what attaches to the inner tie rods ?
Old 08-06-2010, 03:56 PM   #13
myoldchevytruck
yep, that's what i'm talking about. like I said in my earlier post, the taper is different between the early and later years. your in so cal, there should be plenty of places to pick on up at. i got mine from a u pull it yard for $5.00
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 08-06-2010, 06:05 PM   #14
Frijolito1988
Yeah I did not know i need a new sway bar. I just got off the phone with auzotone and they have all the parts, inner outter tie rods , upper / lower ball joints. Should be aroun $120 or so.
So there is no way i hell that the inner tie rod will connect with the sway bar that is on the truck now ?
Damn i gotta start calling people , LOL.
Old 08-06-2010, 06:12 PM   #15
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Sway bar and Center link are different.Make sure you use the term center link or you will be looking at the wrong part.The sway bar is kind of a wide U shape.The center link will be straighter.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-06-2010, 06:18 PM   #16
Frijolito1988
Ok so the sway bar is the same on these trucks , what I need is the center link ? That connects the inner tie rods ?
Old 08-06-2010, 06:38 PM   #17
Frijolito1988
I'm thinking. If I only replace the outer tie rods, then I can leave the center link and inner tie rod alone right ? I will only change the outer tie rods , and upper/ lower ball joints.
Old 08-07-2010, 06:22 AM   #18
myoldchevytruck
Frijolito - PanelDeland is right, the sway bar and center link are 2 different things. I referred to the drag link (also known as the center link - sorry if I confused you at all) Anyways, I think your best bet is to try and locate a center link and to buy new inners. I realize that this may set you back in getting your truck back together but in the long run, you'll have new steering parts. I was lucky enough to locate one in the u pull it yard. there are members always selling parts in the for sale section and I'm sure you can get a center link there. Become a Subscribed Member, It'll be the best $25.00 you spend all year.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 08-08-2010, 07:35 PM   #19
Frijolito1988
thanks for all the input guys, We have the disc installed minus the
-drag link
-Inner tie rod
-Tie rod adjusting sleve
now my Autozone has the inner tie rod and adjustable sleve , Does anybody carry the drag link new?
I looked thru classic industries , brothers and truck shop magazine and nothing. I see they carry them for other years. Anybody know where i can find a new one ? I see they are under $40 for other years so if i can find a new one for that price id just perfer to get a new one. Or if anybody has a lead in a used one on a forum and is willing to ship , let me know! , Thanks guys.
Old 08-08-2010, 09:21 PM   #20
69pickupnyc
I recently put front disk brakes in my 69 pickup from a 71 truck. you will need to change the upper and lower ball joints to 71-72 and tie rods inner , outer and sleve. I would recommend going to cpp and buying the parts from them I found them very helpfull. I would also recommend buying front brake lines for a 71 that are formed for the truck and brake hoses. joe 1-718-634-1268
69pickupnyc is offline   Reply With Quote
Old 08-08-2010, 09:45 PM   #21
Frijolito1988
So did you leave the drag link the same ? You mounted the new inner tie rods to the old drag link ?
Old 08-08-2010, 10:19 PM   #22
69pickupnyc
I left the old drag link
Old 08-08-2010, 11:23 PM   #23
Frijolito1988
and the truck drives fine and it bolts up good ?
Old 08-11-2010, 10:09 PM   #24
Frijolito1988
So guys I purchased the master cylinder from Autozone,
As far as the proportioning valve goes, I think classic industries wants $150+ for one. Am I looking at the wrong part ? Where would be the cheapest way to find one ? Also as far as the brake lines go . I only need the front lines that go from the proportioning valve to the brakes ? Can i re use the steel lines but I need to change the flexible ones ? help is greatly appreciated , thanks.
Old 08-12-2010, 12:23 PM   #25
Frijolito1988
Bump
