DIY fuse panel/relay for LS motor
Guys,
If I plan on running the factory 5.3 motor in my truck, is there any reason to get a stand alone fuse/relay panel to control my fuel pump? Has anyone used the factory junction box in their project? David ________ Last edited by djw32; 08-13-2010 at 02:04 AM. |
Re: DIY fuse panel/relay for LS motor
Second thought,
Nevermind. Last edited by djw32; 08-13-2010 at 02:04 AM. |
Not sure if this is what you are asking but I hope it helps. It is located in the
"Ls engine swap info" stickyThread ... the link inside that thread says "LT1swap" Lots of wiring info. http://lt1swap.com/underhoodfuseblock.htm
Harrol 1968 SWB 1968 SWB 4x4 1969 Suburban 1970 LWB 1970 Blazer 2002 Tahoe Inside every older person is a younger person wondering what happened |
Harrol,
Good call on that link. I forgot to grab the junction block when I picked up the motor...I wasn't thinking. Last edited by djw32; 08-13-2010 at 02:03 AM. |
I posted this in my build thread that you asked about, but here it is again...first item on this page is what I used:
http://www.currentperformance.com/Ac...iring_acc.html Also, I have a factory fuse block that I didn't use. |
#6 | |
| Bookmarks |
