Old 08-12-2010, 11:37 AM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Which motor mounts set the motor back the most?
I had the ECE mounts, now I have the Car Shop mounts, havent installed motor yet with new mounts, but it looks like they might set the motor even more forward than the ECE mounts. So which mounts would set the motor back the most?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 08-12-2010, 11:42 AM   #2
team39763
Re: Which motor mounts set the motor back the most?
Have you tried the 1" setback mounts that carshopinc makes? I had their regular mounts, but switched to another brand's 1" setback since carshopinc didn't make them at the time. It set my motor exactly where the old sbc used to be and my trans bolted right up.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 08-12-2010, 11:44 AM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I didn't know they had 1" setback mounts. I just received CSP 2349 mounts yesterday, will try to reinstall tonight. Thanks!
Old 08-12-2010, 11:50 AM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Dangit, if I would have known about those CSP 2370, I would have ordered them instead. Thanks for the info Team39763!
Old 08-12-2010, 09:58 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
#2 and #3 are the most common plates.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-13-2010, 12:26 AM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ok, ya so now I'm mad. I had the ECE mounts but sold them because the mounts were about 1" too far forward, now I have the Car Shop CSP 2349 mounts and its even worse. I want a LS motor mount that I will be able to use the LS clutch fan and the original 72 fan shroud, and the bellhousing flange meet up the trans. that is in the truck. Any suggestions? Thanks for the diagram Glock, I can visually see what I need now, who makes or sells the # 1's? I think that is what I need. Thinking about returning my 2349 for the 2370.
Old 08-14-2010, 12:12 PM   #7
glock35ipsc
No one makes #1 commercially that I am aware of. Someone might, but I just haven't seen them. I just included it in my diagram for the engine mount sticky. If those are the ones you need, they are super simple to make.
These would be the closest:
http://tpiparts.net/inc/sdetail/16936
Bob
Old 08-15-2010, 01:48 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Thanks again Glock, you da man, I looked at those and considered them at first.
Old 08-16-2010, 11:26 AM   #9
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used the POL stands, on the rear mounting holes and then used their mount plates too. I could use the shroud with a little trimmin.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-16-2010, 11:31 AM   #10
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I just ordered the tpiparts plates, shipped express, and will be returning my Car shop mounts. Hopefully I will be putting it in for the last time tomorrow.
Old 08-16-2010, 12:32 PM   #11
c10seconds
c10seconds's Avatar
Let us know how it sits. I may have to order some of those as well
c10seconds is offline   Reply With Quote
Old 08-20-2010, 11:23 AM   #12
team39763
Mine sorta look like the ones in #1. I couldn't get a real good look at them since my hood is stuck. I believe mine are the S&P 1" setback mounts. Shortly after I bought mine to replace my standard carshopinc mounts, carshopinc started making 1" setback mounts.
Old 08-20-2010, 11:30 AM   #13
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
They fit good. a little thick though, about 3/8" thick. I had to slot my engine stands and the frame in order to get the motor to set down on the stands with the adapters and Prothane mounts. I used them in the most forward position, so that I could use the LS fan and 72 shroud, but now I can't mount my a/c compressor in Ls fashion. With the ECE mounts I could use the LS a/c compressor in it's normal location, but the Ls fan was real close to the radiator. Had to notch the bottom of shroud to clear water pump snout, and install fan and shroud as 1.
Old 08-23-2010, 12:15 AM   #14
eagleuh1
eagleuh1's Avatar
Have you tried using 6 cyl stands in rear position with the # 2 plates. This is what I used. Engine sits back pretty good.
eagleuh1 is offline   Reply With Quote
Old 08-24-2010, 02:50 PM   #15
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Question Re: Which motor mounts set the motor back the most?
Nope haven't tried that. I was able to slot stands and frame and it sets back good. Still able to use Ls fan and 72 shroud, but a/c compressor doesn't fit in stock location. Oh well I guess we can't have it all.
Old 08-28-2010, 10:19 PM   #16
joejbal
joejbal's Avatar
I agree, I used the 6 cyl stands with plates like number two, and a urethan version of the stock type mount. the engine sits very close to the firewall, like it was meant to go there.
Joe
joejbal is offline   Reply With Quote
Old 09-10-2010, 04:14 PM   #17
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Does the AC comp fit in there with the motor mounted like this?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 09-10-2010, 08:57 PM   #18
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Mine doesn't. I think I will have to go with the high mount bracket.
Old 09-11-2010, 07:28 AM   #19
eagleuh1
eagleuh1's Avatar
Mine does but I made my own compressor mount to move the AC in closer to the engine. No good pics available. Wish had taken some before engine install. I got some compressor blocks from Docs Blocks.com. Have put on yet.
Old 09-20-2010, 07:44 PM   #20
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I'm hoping someone here can help. I too had the ECE mounts and found them to mount the motor too far forward and am now using some Transdapt mounts that are similar to #1.
My question is.....now that I have the motor so much further back...will I still be able to get the cab on?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-20-2010, 07:51 PM   #21
68GMCCustom
Mine is using 6cyl mounts and the rear holes...plus the mounts look like the set back further....too far back?
Kurt -
Old 09-20-2010, 09:14 PM   #22
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
That's my pic.
Old 09-21-2010, 10:46 AM   #23
68GMCCustom
well duh.
I was using your pic for comparison.... because I didn't have any of mine...now I do...here's mine:
Kurt -
Old 09-21-2010, 09:54 PM   #24
68GMCCustom
I guess the more I look....the motor mount looks to be in the same location on the motor plate as yours chevydog?
Kurt -
Old 09-21-2010, 11:01 PM   #25
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yep, it's just that you have your towers in the most rear holes. I have mine in the front 2 holes on the frame.
