Old 08-29-2010, 09:12 AM   #1
CVA59
Dimensions Please
Can someone tell me what the inside to inside of the fender is on a short fleet? it is to the inner lip of the outside bed side fender opening.
Zack
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 08-29-2010, 09:56 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Dimensions Please
On my truck 12 1/2". 1963
Old 08-29-2010, 01:54 PM   #3
CVA59
Thanks for this info AERO. I am needing the dimension from inside fender lip to inside fender lip. Thanks
Zack
Zack
www.23t.weebly.com
Old 08-29-2010, 03:05 PM   #4
aerotruk63
aerotruk63's Avatar
Can you make a drawing or show a picture of what you need then?
Old 08-30-2010, 12:55 AM   #5
Captainfab
60-66 Nut
I believe what Zack is asking for is the measurement from the inside fender lip on the drivers side to the inside fender lip on the passenger side. It should be around 70" plus or minus.
Sorry I can't help with this ATM Zack. I might be able to tomorrow if someone else hasn't by then.
Old 08-30-2010, 05:47 AM   #6
aerotruk63
aerotruk63's Avatar
Thank's Captain, then if the width of the rear fender opening was 12 1/2", double that, plus 50" = 75" +/-.
Old 08-30-2010, 08:38 AM   #7
CVA59
Now we're cookin. Thats exactly what i needed, Sorry for the confusion. Thanks guys.
Zack
Zack
www.23t.weebly.com
Old 08-30-2010, 10:18 AM   #8
padresag
the illustration at the top of the page shows the dimension of 72" for the overall width of the box so therefore the inner dimensions of the lip cannot exceed that measure. the est by the Capt seems about right at 70" figuring about 1" for each lip
ron
padresag is offline   Reply With Quote
Old 08-30-2010, 01:17 PM   #9
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
ron
something wasn't jibing with the measurements so I did this:
my bed is disassembled so, using the cross sills, the measurement to the wheel tub mounting surface on the fenders is 72"
(this was 71" from outermost bolt hole CL's on cross sill + 1/2" (as measured)each side for bolt hole to tub mounting surface, 71 + 1/2 + 1/2 = 72)
this already means the illustration above must be wrong
the distance from the tub/fender mounting surface to the inner flange surface is 1 1/2" each side. (the flanges, BTW, are each 1 1/2" deep).
all this gives 75"
also, just for cross reference:
the depth of one of my wheel tubs is 11" and the distance from the tub mounting
surface on the fender to the inner flange is 1 1/2" = 12 1/2" which is the same as aerotruk's
earlier measurement
Larry
fleetsidelarry is offline   Reply With Quote
Old 08-30-2010, 01:18 PM   #10
CVA59
Great info Larry. Thanks for confirming this.
Zack
www.23t.weebly.com
Old 08-31-2010, 12:12 AM   #11
Captainfab
60-66 Nut
I measured the width on a '63 SWB that my son just bought, and it measures 75 7/8" from inside of left fender lip to inside of right fender lip. The bedsides don't really look flared out, but I suppose it is possible that they could be out 7/16" each side. I guess I need to measure the inside of the wheel well to the lip and see if it is 12 1/2".
Old 08-31-2010, 09:19 AM   #12
CVA59
Thanks again Fab, that is the exact dimension i am needing.
Zack
www.23t.weebly.com
