Old 08-29-2010, 10:59 AM   #1
Lee H
Lee H's Avatar
A/C & Heater control cables
I finally installed a NOS A/C heater control unit replacing a not so good repop. Much better quality. I played with the repop cables for quite a while and can not get them to operate properly, not even close. I swapped cables positions several times between the levers and still no luck. I have never played with these types of cables before. Any advise would be appriciated. (I do have the assembly manual showing the correct position and location of the cables). Maybe it's a matter of getting OEM cables? Thanks.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-29-2010, 11:45 AM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: A/C & Heater control cables
Not sure on the repop cables, but on the originals if you will lube them with some teflon spray or if you can get some good grease down inside them, it'll help immensely!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-29-2010, 08:35 PM   #3
71 super
71 super's Avatar
The cables were still available from GM a year or so ago, but they needed a special tool to crimp the clamps onto the actual cable (some assembly required). You might check with classic muscle in Winston- salem NC to check availability.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-29-2010, 08:43 PM   #4
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
The clamps can be opened up and moved where you need them. Mark the correct location on the cable housing, then use a cold chisel to set them in place.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
hounddogs! is offline   Reply With Quote
Old 08-30-2010, 10:49 AM   #5
Lee H
Lee H's Avatar
OK, thanks, I'll call classic muscle. Anyone have a picture of the tool or have one for sale?
