![]() Join Date: Feb 2003
automatic column indicator light
installed a 72 automatic tilt column in my 67 stepside. relocated the NSS up the column 2 3/4 inches and installed a female horseshoe connector to match up with the column horseshoe cpnnector. i have one extra wire going up the column..a gray one...is this the power source for the shift indicator bulb? and if so, is the gray wire wired into the dash lights circuit...thanks for help!
Firefighter
There should be a place in the fuse box to plug it in, that's where I put mine so it comes on when the dash lights do.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Re: automatic column indicator light
That's a pretty safe bet. Gray is the standard GM color for instrument lighting.
Ray |
Yes, that grey wire is likely a dash light source, check with a meter or test light to be sure. The 72 shift indicator light is light by a fiber optic cable from the back of the dash, not a wire and light bulb like prior years. Not sure which years used the fiber to light the shift indicator.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
member #16
![]() Join Date: Dec 1999
Plug it on the cluster feed on the fuse panel.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
yes you are all correct. went out first thing this morning and plugged into the fuse panel.indicator light works and dims properly. thanks for the replies.
