Old 08-31-2010, 11:52 PM   #1
drewmangoo
drewmangoo's Avatar
need help with exhaust setup for in-line 6
try to find info on exhaust setup for inline 6 (230) . I need to run exhaust pipe from header back, every shop I call wants to charge between 150-170, I want to do it myself pretty good at welding, does anyone have a picture or info so i can see angle of pipe I need to run. Thanks
Keep knockin' on the Devils door, eventually someone's gonna answer.
1965 c10 Longbed Fleetside
1972 Chevelle (wife's car)
2002 Suburban (wife's car)
drewmangoo is offline   Reply With Quote
Old 09-01-2010, 12:06 AM   #2
bubba327
HOW long until spring??
bubba327's Avatar
Re: need help with exhaust setup for in-line 6
I used 2"EMT conduit and a hydraulic bender from work.--
Kicked it outside the frame and turned it out in front of the tire.
http://67-72chevytrucks.com/vboard/s...d.php?t=365170
Check it out Page 6 -Bubbas recycling project in 60-66 project and builds
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 09-01-2010, 12:08 AM   #3
drewmangoo
drewmangoo's Avatar
Thanks thats just what i needed, your the man.
Old 09-01-2010, 09:28 PM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
FYI, I have a decent exhaust on my truck currently (292 though) .... I plan on ripping it out, and running something different.
Flows into a flowmaster, then splits in front of the rear wheels.....looks recent (few years I guess)
If you can use it, your welcome to it !!
Here's a pic:
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-02-2010, 06:17 PM   #5
drewmangoo
drewmangoo's Avatar
[ATTACH]Name:  IMG_0945.jpg
Size:  55.6 KB[/ATTACH]
Chief this how my engine looks, would that work?
Old 09-03-2010, 12:11 AM   #6
raycow
Just a friendly suggestion, which I know you didn't ask for......
Unless you have another connection on the valve cover which doesn't show in that pic, you should run a vented cap with that PCV setup. Otherwise, there is no way for fresh air to get into the crankcase.
Ray
raycow is offline   Reply With Quote
Old 09-03-2010, 01:00 AM   #7
drewmangoo
drewmangoo's Avatar
No prob, Ray that's not engine just found this picture to show what exhaust flange looks.
Old 09-04-2010, 03:10 AM   #8
old cruiser
old cruiser's Avatar
[img]
Standard manifold. Pipe joint here thru hotdogs exiting out rear below bumper bar
old cruiser is offline   Reply With Quote
Old 09-04-2010, 09:25 AM   #9
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looks close ... If anything, you might just need to rework the flange area only....The rest of the pipe would be fine.
Mabey someone else will chime in regarding the flange connection ...
Let me find another pic.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-04-2010, 09:41 AM   #10
bubba327
bubba327's Avatar
I just recycled the first foot with the flange and welded on new from there. 2" EMT is a little bigger diameter but not much.
I have made new flanges before by heating with a torch and working it over a ball hitch. Bubba
Old 09-04-2010, 11:53 AM   #11
Shaky
Six in a row makes it go...
Shaky's Avatar
I took a Y-pipe for a Nova that was laying around and cut the ends off. Then I welded new ends on that were oriented correctly. This was a 2 into 1 exhaust.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 09-05-2010, 01:50 AM   #12
drewmangoo
drewmangoo's Avatar
I might have to try some of these ideas,that's the only thing holding me from driving my truck. I can't seem to find a flange to hookup to manifold,getting fustrasted.
Old 09-06-2010, 06:05 PM   #13
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: need help with exhaust setup for in-line 6
You need to look here!
http://67-72chevytrucks.com/vboard/s....php?p=2967357
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
